Calculating Heat of Reaction for Copper Metal | 1.25 g from 37.6°C to 96.2°C
In summary, the change in heat of a reaction is the energy absorbed or released during a chemical reaction. It is measured using a calorimeter and can be affected by temperature, pressure, concentration, and the presence of a catalyst. The change in heat of a reaction is also known as the enthalpy change and can be either positive or negative, with a negative change indicating energy release and a positive change indicating energy absorption.
klouvi2
The specific heat of copper metal is 0.385 J/g ·°C. How many joules of heat are necessary to raise the temperature of a 1.25 g block of copper from 37.6°C to 96.2°C?
g x g / mm
1.25 g x 1 g / 63.546 mm = .01967 mol
What equations that deal with the amount of heat do you know? Please check your notes and/or textbook.
1. What is the definition of "Change in heat of a rxn"?
The change in heat of a reaction is the amount of energy absorbed or released during a chemical reaction.
2. How is the change in heat of a rxn measured?
The change in heat of a reaction is measured using a device called a calorimeter, which measures the temperature change of the reactants and products.
3. What factors can affect the change in heat of a rxn?
The change in heat of a reaction can be affected by the temperature, pressure, concentration of reactants and products, as well as the presence of a catalyst.
4. How does the change in heat of a rxn relate to the enthalpy of a reaction?
The change in heat of a reaction is also known as the enthalpy change, which is the difference in energy between the products and reactants in a chemical reaction.
5. Can the change in heat of a rxn be negative?
Yes, the change in heat of a reaction can be either positive or negative. A negative change indicates that the reaction releases energy, while a positive change indicates that the reaction absorbs energy.
