Changing the direction of the acceleration Vector
The discussion centers on the behavior of an electron in an electric field created by two point charges, where the electric field at point P is directed to the left, while the electron experiences an acceleration to the right. The challenge is to understand how to switch the direction of the acceleration vector without simply multiplying by a negative scalar in the equation E(-e) = m(acc). Participants highlight that the force experienced by a positive test charge is repulsive, while a negative charge like the electron accelerates toward the positive charge due to the electric field gradient. The conversation emphasizes the complexity of interpreting forces and accelerations in relation to charge types and their respective fields. Ultimately, the key question remains how to reconcile the direction of acceleration with the established electric field direction.
orthovector
2 point charges. q1 is -25 microC and q2 is 50 microC are separated by a distance of .1m where q1 is on a line that connects q1 to q2 and q1 is to the left of q2. point p is .02 m to the right of q1 and .8m to the left of q2.
E = F/q
E(e) = Force on electron due to Electric Field
okay, so the electric field at point p due to these 2 point charges is -6.3 E 8 N/C dot i.
if we put an electron at point p, the electron will feel an acceleration.
the electric field points to the left at point p. yet, the electron feels an acceleration vector pointing to the right. How do I switch the direction of the acceleration vector without multiplying a negative to the equation E(-e) = m(acc) where E = -6.3 E 8 N/C dot i ?
so? anybody with any ideas?
Your Force equation is the product of the charge scalar and the E-field. Your e-Field at p is -x. But there is a - carried with the e. This reverses the acceleration that the charge will experience.
there's got to be another way to switch the direction without multiplying by the negative scalar. If you look inside the Force equation...
f = q q k / r squared dot unit vector r. however, I'm not sure if the positive test charge feels a negative or positive force from the source.
Positive test charge experiences positive force (repulsive force) outward from the point charge. The r vector of force is negative directed at that point as a result of the negative position from the net outward from the dominating positive. As a negative the electron however wants to accelerate opposite, i.e. toward the positive point, against the positive gradient, but of course only there and not beyond.
