Finding the Zero Electric Field Position on the X-Axis - Homework Solution
  • Thread starter Thread starter flynostrich08
    Charge Position
To find the zero electric field position on the x-axis between a 6μC charge at the origin and a -10μC charge at x = 5cm, one must apply the principles of electric fields generated by point charges. The initial calculation presented (6/16 * 0.05 = 0.01875) is incorrect and does not align with the necessary equations for electric fields. Participants suggest reviewing relevant equations from textbooks or lecture notes that relate charge to electric field strength. The solution involves determining where the electric fields from both charges cancel each other out. Understanding these concepts is crucial for accurately locating the zero electric field position.
flynostrich08
A 6μC charge is placed at the origin and a -10μC charge is placed on the x-axis at x = 5cm.
Locate the position on the x-axis where the electric field is zero.
6/16 * .05 = .01875
I have no idea if this attempt is right, thanks for any help
flynostrich08 said:
6/16 * .05 = .01875
That seems to be just some random calculation involving the given quantities. Sorry, no, it's incorrect.
Reading this question, I see the key phrases "charge" and "electric field". Check your book or class lecture notes for any equations that relate those things. That would be a start towards solving this one.
