Circuit design question. Prototyping.
The discussion revolves around the design and prototyping of a circuit using a 555 or 556 timer chip for a sequential tail light kit in a car. Participants explore various methods for creating a durable and weatherproof circuit from a breadboard setup, including etching PCBs and using perf-board.
  • One participant describes their project involving a 556 chip and seeks advice on transitioning from a breadboard to a more permanent solution.
  • Another participant suggests that etching a board is an option, but also mentions the possibility of using a boardhouse for a more hands-off approach, recommending freeware layout programs.
  • A third participant expresses a preference for using a perforated grid proto board for small applications, highlighting its compatibility with various ICs and transistors.
  • One participant outlines a method for etching PCBs using "press and peel blue" and ferric chloride, noting its simplicity and cost-effectiveness, while also mentioning the use of a mechanical PCB router as a more advanced option.
  • A later reply indicates a decision to use the toner method for etching and inquires about free PCB CAD software for OSX, expressing a preference for software that does not require running Windows.
Participants present multiple approaches to circuit prototyping, with no consensus on the best method. Various opinions on etching, using perf-board, and CAD software reflect differing preferences and experiences.
Participants discuss the need for durability and weatherproofing in their designs, but specific requirements and limitations of each method are not fully explored.
Shadow787470
Some of you may have seen my thread where i am using 555 (more then likely a 556 instead)
to make a sequential tail light kit for my car. Its a pretty simple circuit that really only consists of the 556 chip, a few small caps, and a few resistors then the relays (currently using LEDs to get everything setup correctly)
Ive just about got it set up correctly i just need to perfect the timing of the cycle. The next problem i face is taking my breadboard setup and making it into something i can actually use.
Ive seen where you can buy copper plated chips and etch them yourself but it that the best method? I need something that will be durable and preferably something i can weather proof a little bit.
I googles a little but "circuit design" is pretty broad.
Can anyone point me in the right direction?
It really just depends on what you want to do. If you want to learn to etch a board, that option is always there. You will have to do some type of layout first and then drill all your holes, plate the board, etc.
If you want a more 'hands-off' approach, you might want to have boards made. There are freeware layout programs that prototype boardhouses use (sunstone.com for example has one). Just Google prototype PCB and you'll find several links.
If you really don't want to do a layout, you could always just get some perf-board and hand wire your circuit.
If you want to weatherproof the design, there is always conformal coating. You would also use a potting compound to seal the circuit if you are still worried about the elements.
For small size and quantity semi-permanent applications, I prefer a perforated grid proto board with copper strips like the Radio Shack http://www.radioshack.com/product/index.jsp?productId=2102845
The 0.1"" grid is perfect for DIP and miniDIP ICs (and sockets), and works well with transistors also.
Bob S
You can use "press and peel blue" and ferric chloride to etch your PCB design on a copper board. This is probably the simplest approach to a PCB prototype.
You essentially print your circuit with a laser-jet printer onto the blue film, iron onto a copper board, peel off the blue, and etch the remaining copper with ferric chloride. It works pretty well although very fine pitch work can come out a bit shotty.
A more elegant way is using a mechanical PCB router. I use one at my work from LPKF. It mechanically removes the copper (like a cnc machine).
For a simple circuit, try out the press and peel - you could probably make a circuit for <20 bucks and have plenty of material left over to make more boards for later designs.
-Joe
EDIT: Actually i found the source of my confusion...
To shorten my post i have decided to etch my own board using the toner method (assuming i can find a printer to use!)
Does anyone know of some easy to use (free) PCB CAD software for OSX?
Im currently using Pad2Pad which has proven pretty easy to use and useful but i have to run windows on parallels which slows things down a little.
  • · Replies 32 ·
  • · Replies 22 ·
  • · Replies 32 ·
  • · Replies 22 ·
