Coefficient of static friction experiment
6 replies · 4K views
physicshelpppp
1. Problem
I am currently doing a home experiment about the coefficient of static friction. I've set up a ramp and am testing at which angle a tissue box begins to movie (with five different masses in it)... Although for every mass I use the angle seems to remain the same. The angle at which an object will start moving is independent of mass right? Mass is important when there is no friction?
The acceleration is given by a factor of $$ g*(sin(Θ) - μcos(Θ) )$$
yes..it doesn't thepend from mass
I have been looking at questions, when I do a worked question...
and the force down (weight force) on the object would be mgsinpheta and the force perpendicular is mgcospheta
which has same magnitude as normal force
so frictional force is = μsN (where is normal force is equal to perpendicular force)
therefore Ffr = μsmgcospheta
the object will start to move when the force down the slope is equal to the maximum friction force
therefore
mgsinpheta = μsmgcospheta
(therefore we can cancel the mg out on both sides)
and then we are left with μs = sinpheta/cospheta therefore μs = tanphetatherefore it is independent of mass?
therefore
it isn't...remember the galileo experiment with gravity :)
