Damped harmonic oscillator for a mass hanging from a spring
The discussion focuses on solving a damped harmonic oscillator problem involving a mass hanging from a spring. The general solution for damped harmonic motion is provided, indicating that the mass will oscillate around its equilibrium position. A hammer blow gives an initial velocity but does not classify the system as a driven oscillator; it simply sets initial conditions. The key is to apply the general solution to fit the specific initial conditions of the problem. Understanding these concepts is crucial for accurately solving the differential equation associated with the motion.
Phantoful
Complex number solutions
z= z0eαt
Energy equations and Q (Quality Factor)
For this question, I followed my book's "general solution" for dampened harmonic motions, where z= z0eαt, and then you can solve for α and eventually getting an answer of x=Ae-(ϒ/2)tcos(ω1t+∅) where ω1=sqrt((ω02-(ϒ/2)2)). This is just for the underdampened case and there are other solutions for the critical and overdampened case. However, I don't think these are the answers and I'm not even sure how to interpret these "general solutions". For this question would the case be any different if a v(0) = v0, and the mass is hanging? Should I treat it like a driven harmonic oscillator because of the hammer? This is the first time I'm answering a question like this one.
All the hammer blow does is to give you a non-zero initial velocity. Otherwise, just solve the ODE for the prescribed conditions.
Likes Phantoful
z= z0eαt
The general solution in the book is applicable to your problem. A hanging mass will oscillate about its equilibrium position. x is the deviation from the equilibrium.
Hitting once with the hammer does not mean that the oscillator is driven., It provides the initial conditions you have to fit the general solution to: At t=0 x(0)=0 and v(0)=v0. Determine A and θ for each case.
Likes Phantoful
Thank you!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
