What Are the Two Possible Values of C in a Damped Harmonic Oscillator Equation?
The equation of motion for a damped harmonic oscillator is given by Ma(t) + rv(t) + Kx(t) = 0. To find the two possible values of C, a solution of the form x(t) proportional to exp(-Ct) is proposed. The relationship between x(t), v(t), and a(t) is essential for solving the equation, as v(t) is the first derivative of x(t), and a(t) is the second derivative. Understanding these relationships will help in deriving the values of C. The discussion emphasizes the need for assistance in solving this equation.
clipperdude21
1. The equation of motion is Ma(t) +rv(t) + Kx(t)=0
a) Look for a solution of this equation with x(t) proportional exp(-Ct) and find two possible values of C.
3. No clue... Please help if you can!
How are x(t), v(t) and a(t) related?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
