DC12V 12A car window motor - what spec for a 220V PSU?
The discussion revolves around the specifications needed for a power supply unit (PSU) to operate a DC motor originally designed for car windows, which is being repurposed for a motorized turntable project. The motor has been tested at 12V and 8A, achieving a speed of around 120 RPM, and there is interest in controlling its speed, potentially using PWM (Pulse Width Modulation). Participants discuss the motor's power requirements, noting that it may draw up to 12A under load, and suggest using a transformer to convert mains voltage to the appropriate level. The project aims to modify motorcycle barrels through material surface impact, indicating a complex engineering challenge. Overall, the conversation emphasizes the importance of understanding motor specifications and control methods for successful project execution.
marcophys
I have a combined motor and screw drive (to 90 deg).
It's original purpose was to convert car windows to electric drive... my guess is that it is at least 25 years old, and made in Japan.
For scale... the width of the motor casing is 50mm (as you look at it)
I'm making a motorised turntable.
The jig is coming along nicely, but I need to start thinking of a PSU and could do with some assistance.
I don't have a PSU but I've tested the motor momentarily on an 8A battery charger.
It rotates at a reasonable speed ie. around 120 rpm.
(I attached an indicator wire to the output shaft and counted 60 turns to 30 seconds)
This is in the ball park area (by amazing good fortune)
It probably has more potential power than I need... primarily I'm looking to rotate up to a motorcycle barrel.
Clearly it would be nice to control the speed... perhaps a bit faster, or a bit slower (more likely).
Maybe I need to have adjustable voltage... perhaps that would be useful for bringing the turntable up to speed.
I have a very nice Rollei PSU - AC 12V max - 100VA - click adjustable 110V, 120V, 130V, 220V, 230V, 240V
I don't need to use it, but I note this for information purposes.
Having looked on eBay... the transformers seem to be highlighted for LED strip, and CCTV usage.
Typically 12V 15A 180W.
None are controllable by 'twist knob' - but I've not gone into it in depth.
I don't mind adding controllers... I can solder.
However, I thought it best to get an overview from the forum, on what direction I should be looking at.
What's a motorcycle barrel?
You need to use PWM of the 12V source to control the DC motor speed. :smile:
Likes Brandon91man
Thank you very much for that lead :)It is the metal casting that contains the cylinder (for the piston).
The outer part of the barrel is either heat radiating 'fins' (air cooled) or it holds a jacket of coolant (liquid cooled).
For the particular barrel - it is in the 1.7Kg range.
I'd be happy to get a result at that, and then learn from the experience.
With all the friction involved with winding a window... I'm thinking that the motor can start a 2kg load.
... but maybe a soft start is always better.
I researched PWM... this stands for 'Pulse Width Modulation'
Here's a very good video introduction to PWM:
(I presume it's good... he has 1.5m subscribers, and in electronics... it might be a worthy reference)
But from his video, it seems to indicate that I should be choosing a 24V source... with the median output being 12V.
Have I understood that correctly (or is he talking bollocks)?
From this, I'm thinking that I need a mains voltage transformer to 24V DC
P = I x V
144W = 12A x 12V
Question
Does this mean that the motor requires 144W regardless of the voltage?
It is not yet clear to me, the spec of the transformer.
My advice is find a secondhand car battery charger at a yard sale or junkpile .
I just returned from my scrap metal recycle yard where there's a pile of about twenty of them .
Most often it's just a broken cord or meter or thermal overload that's gone wrong. The transformer and rectifier are usually salvageable.
marcophys said:
Question
I suspect the D12A is a model number not its current rating. 144 watts is almost 1/5 horsepower which should lift 110 pounds 1 foot per second.
It might draw that much if stalled though. You'll have to test it to see.
DC motors draw current in direct proportion to their load. Unloaded it'll probably draw only an amp or two is my guess.
Be aware that some window motors have a rubber safety clutch inside that round gear . Its purpose is to limit how much torque the motor can apply to the window lift mechanism so as to not cut off a limb when kids are playing with the electric windows. It shears and you have to replace it.
Yours may not, some simply use a lower torque motor.
With how long a lever arm, ie how much torque ?
Windshield wiper motors are also worm gear drive and will handle continuous duty.
Fun project. Look for hobbyist PWM kits they're not expensive.
Likes marcophys, Brandon91man, Asymptotic and 1 other person
No. It means the amount of current can be as high as the rated 12 amps (provided it is 12 amps; see Jim's post #4). At 12 volts, and 12 amps, electrical input to the motor is 144 watts (12V x 12A =144 watts).
How much current flows through the motor depends on mechanical load at the output shaft. As mechanical load increases, so does the amount of torque (current) required to turn it.
For example, perhaps once you've loaded it, the motor demands 6 amps at 12 volts (72 watts). 72 watts of power requires 6 amps at full speed (12V). If the speed-to-power relationship is linear (possibly the case here, but not so with fans and pumps, and a variety of other loads) you can estimate how slow you can go. 6 volts (half speed) is required to create 72 watts at the 12 amp rating limit.
Likes marcophys
Thanks for the contributions.
It's hard to bear... the thought that it's not 12A... you know... similar size font and directly above the volts :)
But yes, it could simply be product no. D-12A
It shows that 'we see what we expect to see'.
Re the windscreen wiper motor... perhaps they were the original source for this product.
I haven't opened the gearbox as yet... I have resisted the temptation.
I needed to first break the back of the jig.
Once that's done, I'll check out the internals, and grease up.
Re the motor amp demand - that's reassuring.
I have a Makita fast charger DC1401
It delivers 14.4V 4.5A = 64 watts
The turntable isn't yet made - perhaps by the end of the day.
Then we can test loads.
I'd check what no-load current draw is, and what it increases to when loaded.
Do you have a way to measure DC current?
If not, get a 0.1Ω, 5 watt power resistor, place it in series with the motor, and measure voltage drop across it.
I=V/R, so a reading of 100 mV across a 0.1 ohm resistor = 1 amp, 10 mV=0.1 amp, and so on.
It isn't a bad idea to measure motor current this way even when a multimeter with a DC range is available; no worries about clearing the meter protection fuse due to start-up surges, etc.
Another approach to speed controlling a low current, low voltage DC motor such as this is to use an LM317 adjustable voltage regulator. It is adjustable from 1.25 volts to 37 volts DC at 1.5 amp output. 1.25 volt minimum voltage output is one downside (it can't be adjusted to zero speed), and another is the 1.5 amp output limit. However, it isn't much more work to add a "pass" power transistor which allows higher current operation (depending on the transistor used, up to 6 to 8 amps).
Likes marcophys
Most basic DMMS can measure up to 10A ( fused) - or use the 0.1 ohm shunt as pointed above.-- I would be concerned that this motor can draw more then 12A, soooo, you may want to try with a 6V battery and get and idea of how much this will draw.
Controlling the DC supply. and therefore speed with a basic PWM is straight forward , once you know the parameters and limits of the motor.
I am still puzzled by "rotate up to a motorcycle barrel", it seems the barrel is the engine casting. Can you post a photo or sketch?
Likes marcophys
So your turntable is not to play music from vinyl disks. Are you making a lathe? Are you rotating objects for spray painting purposes? A lathe needs much more torque.
Time for a pause, to see where we are
This project concerns material surface modification through impact.
This ranges from renovation, through dimensional modification, to densification.
Most commercially produced vertical and rotational control systems are highly controlled.
Both operate slowly.
I always knew that (with help) I could easily control the rotational speed, however the effect of the moving metal (as it is impacted), is as yet unknown.
We must presume that a circular delve becomes increasingly elliptical.
Aerospace operations typically appear to be sub 10 rpm.
... but they have total vertical control... at this moment... we don't!
We have an orange squeezer... but that is for primary examination of the rotary aspect of the jig.
Vertical motorised control must be relegated to a 2nd project.
Objects For Modification
Soft aluminium, through cast iron, to hardened steel.
This is a typical 2T m/bike barrel:
The top photo shows the cylinder, surrounded by a cavity.
Within the cavity, circulates coolant - driven through a radiator (by a pump).
The bottom photo (top right) shows the large circular coolant duct.
It is through this duct, that the coolant is pumped.
Note: always carefully inspect this duct, to ensure it has been fully drilled, and that there are no obstructions - at pain of engine seizure.
Staying with the bottom photo... there are two arced ducts top and bottom (transfer ports).
The bottom duct (looking carefully) shows that it is split into two (at an angle).
Move your eyes up to the two arced oblong ducts (ports) in the cylinder wall.
These ports feed fuel into the cylinder (across the piston crown), and are fed via the transfer ports.
The third transfer port (top left) feeds fuel through a port not shown.
That port is angled upwards.
The fuel gas is injected upwards, displacing the remaining combustion fumes, forcing them out through the exhaust.
(note how the exhaust is opposite this transfer port)
The elliptical delve above the ports is an 'oil retention reservoir'.
Oil can become trapped in the rough surface, and drip into the cylinder, as the piston passes.
The piston glides through this cylinder, riding on 'piston ring' contact.
We need to carry oil molecules (oil bearings) between the piston and the cylinder.
We also need to eliminate snagging of the piston ring edge between the ports and delves.
We also wish to increase the hardness of both piston and cylinder, to enable them to act like true 'load bearing surfaces' and to minimise the transfer of aluminium (deposits) from the piston to the cylinder.
Note: Evidently there are numerous complex objectives to hand - the piston traverses the cylinder typically over 300 times per second - with an explosion over 150 times per second.
However, from this brief introduction, we can understand why we might wish to employ material modification techniques... and hence this project.​
This is typical 'prototype engineering' on a shoestring.
Older members will immediately recognise this as the true route to understanding the issues at stake.
Younger members may wonder why the correct motor and gearbox (et al) was not specified first.
The fact is... that the final definition anyway, rests in a fog.
... so we grab what we have available... and then with, community knowledge, make it happen.
... and then share the outcomes, back into the community.
Ultimately, we will be able to determine an ideal spec... but (regardless) we will have got the prototype working correctly, and gained all the requisite knowledge.
Hence the member requirement for fundamental motor data (for starters)
Here's where the project is:
  • Window motor
  • Cut down 10mm bolt - ground to the motor 'spline drive'
  • Modified water pump 'threaded ground spigot' (over the bolt thread)
  • Water pump seal (to ground spigot)
  • The above fitted in an IP rated electrical box.
  • Outer guide bearing and cover plate (combined) - perspex/acrylic vehicle registration plate.
    Note: Drills cut small in this plastic - allowing final cutting with metal polish between the spigot and plastic
    An additional O ring will be added to further protect this bearing surface.
Electrical Testing
Here's a cautionary tale:
I had left my multimeter ON (for whatever reason).
When I came to it, I found the battery dead, the fuse broken, and the copper bar split.
I replaced the fuse, and soldered the bar - for no other reason than, that was all I could do.
My finger is touching where it was soldered:
I do not know the implications of this failure... perhaps somebody can enlighten me.
Here is the front face of the meter:
Electrical parts
I have numerous pieces of kit for spares.
An old standard PC PSU might be useful:
It seems to contain plenty of resistors.
If anybody has any ideas on what bits might help us... that would be great.
Tomorrow I will start checking resistor levels.
Haha- thanks for the write up and pics. For me at this point the the speed control of the window motor is pretty well understood. How do you want to control this, with a knob, a digital setting? What is the budget? -- It can be done very cheap with discrete components, or for a little more digitally with something like an arduino - but still need to figure out how much current the motor will draw.
So you want to mount the "barrel" on the turntable to do some process on it? The you mention "material surface modification through impact" - this part has nothing to do with the turntable, but you are looking to process the inside of the cylinder, this is with impact? -- kinda like honing - but with a "hammering" ? -- Sorry - it is just something I have not come across before - and am intrigued.
Shot peening perhaps?
Yes... but imagine whacking a static piece of metal with the ball end of a hammer: the delve would equate to the shape of the ball.
But if the metal is sliding past - perhaps the delve is elliptical - perhaps densification is reduced due to the spreading of the impact force across a larger surface area.
If the cylinder diameter is 47mm - the length of the steel = 147mm
If rpm = 120
In one second the metal has moved 294mm
Therefore, in 1ms the metal has moved 0.3mm.
This 'feels' way too much... and likely hence why the pro turntables run much slower.
Some (for turbines) are in the 0.1 - 1 rpm range
... but let's not forget that the larger the diameter, the faster is the 'passing' metal.
So really the rpm is derived from the permissible mm/sec movement of the surface.
Ie. a smaller diameter shaft could be rotated at much greater rpm, to achieve the same effect.
Vertical movement
Ideally the impact point (or spread of impact points) would would drop after one rotation.
This implies steps.
However, due to the width of the impact band, a controlled descent will have the impacts slowly screwing down, with the impact band overlapping the previous, to achieve uniform impacts all the way down the cylinder.
Oh yes... re budget
Shoestring.
For prototyping I try to use what I've got.
The PWM controller must be bought... but they are inexpensive.
I think that I have everything else.
Re the administration of control.
It would be evidently very nice to have a little computer.
This would be great for calculating motor rpm from the diameter.
Enter the diameter, and the turntable rotates at the correct speed.
I think this would be a great 'phase 2'.
In the meantime, a rotary knob would be ideal.
Perhaps an rpm output is available - I need to check the pre assembled little units on ebay.
This one has a soft start setup :http://www.ebay.co.uk/itm/DC-12V-80V-30A-Soft-Start-PWM-Motor-Speed-Controller-LED-Digital-Display-Panel-/332160641318
... but none so far indicate rpm.
This controller doesn't have any terminals to connect a speed potentiometer ("speed knob"). It uses a pair of 'up/down' pushbuttons to set speed.
Set 5: "000", "002" , "005" , "010" , "015", "020" , "025", The speed changes by 1%, 2%, 5%, 10%, 15%, 20%, 25% each time you press the up or down button.
I didn't see any way to zero and span the digital display - it is fixed to 0 to 100%. If meter zero and span were adjustable, what you'd do is set 'zero' to read '000.0' at zero speed. Next, turn on the drive, run it at maximum speed, independently measure turntable RPM (for instance, by using a stopwatch, and counting revolutions), then adjust meter 'span' to read out the measured RPM. Provided the relationship between actual turntable speed, and whatever it is the meter measures (for instance, armature voltage) are adequately linear, the meter is now scaled, and will display turntable RPM.
Pretty sure - it is not really speed control, but just PWM control. The % is the % of the full voltage. Meaning the speed will vary as the load changes, may not be an issue in your case.
Also - it still need the DC power supply.
I'll have a look at the motor next.
I wanted to get the turntable disc completed, because I knew it would be fiddly, and noisy to cut with a jig saw.
Anyway, it's done, and here it is:
This provides support options for large and small diameter workpieces.
RE the comments concerning the PWM controller.
Yes I need to be careful.
I showed that link primarily because it had a 'soft start', which I thought was quite neat.
Interesting that the speed would vary by load... say changing from a cast iron barrel to an aluminium piston.
I'd never considered that.
It looks like the ideal would be to digitally control the rpm, regardless of weight.
Perhaps that's impossible with this motor.
If so, a strong magnet attached to the disc might work.
The sensor would need to be in the motor enclosure, and the field must pass via a steel grill 2.5mm thick:
It would be possible to project the sensor external to the enclosure - perhaps through an enlarged hole.
However, this is a messy solution, and best avoided if possible.
If you have an old fashioned "Variac" adjustable transformer, that and a car battery charger works very well. Would get your experiment going quickly.
Old Ford windshield wiper motors had three brushes hence superior speed regulation. And lots of torque. If you can't close your speed control loop , consider that option for open loop.
No I don't.
I am currently testing with an 8A/4A battery charger.
Voltage
4A delivers 12V free of load
8A delivers 13.55V free of load
4A delivers 10.3V motor load - no weight
8A delivers 12V motor load - no weight
4A delivers 9V motor load - 1Kg
8A delivers 10.9V motor load - 1kg
4A delivers 8.7V motor load - 2Kg
8A delivers 10.3V motor load - 2kg
Notes:
  1. The Voltage delivered is varied - I've made a median guesstimate
  2. The RPM drops with weight, as predicted by project contributors
Interesting that the voltage drop lessens, as the load increases.
Next tests will be RPM, and Amps.
RPM
4A delivers 10.3V motor load - no weight - 88 rpm -
8A delivers 12V motor load - no weight - 104 rpm -
4A delivers 9V motor load - 1 kg - 60 rpm -
8A delivers 10.9V motor load - 1 kg - 80 rpm -
4A delivers 8.7V motor load - 2 kg - 54 rpm -
8A delivers 10.3V motor load - 2 kg - 68 rpm -
Notes:
To prevent the onset of madness... counting was restricted to 30 seconds - the figure then doubled.
For the bulk of each period, the count establishes it's rhythm, allowing the eyes to stray to the stop watch.
I would judge the accuracy to be +- 1 rpm
Load - RPM - Amps
4A delivers 10.3V motor load - no weight - 88 rpm - 1.5 A
8A delivers 12V motor load - no weight - 104 rpm - 1.6 A
4A delivers 9V motor load - 1 kg - 60 rpm - 2.1 A
8A delivers 10.9V motor load - 1 kg - 80 rpm - 2.8 A
4A delivers 8.7V motor load - 2 kg - 54 rpm - 2.3 A
8A delivers 10.3V motor load - 2 kg - 68 rpm - 2.4 A
Notes:
Again, there was variability.
Perhaps this is due to the past wear of the worm drive.
Bear in mind that we are not dealing with magnetic or airless bearings.
However, the results should provide a guide.
Perhaps a spreadsheet plot might throw up any human misjudgement.
What can we derive from the test results?
I'm thinking that the voltage should be regulated to a fixed voltage - say a figure less than 10 volts.
In this respect, the voltage would become fixed.
I need to test with the Makita charger specced at 14.4V @ 4.5A
But with a fixed voltage. this would stabilise the rpm, and only amperage would change.
... or is this unnecessary with PWM - in effect, itself stabilising the voltage?
Rather than focusing on the drive controller for now, if turntable speed is currently in the ballpark, verify you can obtain the peining effect you are after. If you can (or it becomes apparent if might work at a slower turntable speed) then put effort into motor speed control.
The PWM controller in your previous post is an open loop control, and outputs 0 to 100% of input voltage (for instance, the battery charger) in increments as small as 1%. Increasing motor load will still reduce supply voltage, and since speed is directly proportional to armature voltage, speed will still fall off as load increases.
To obtain regulated speed control it is desirable to close the loop by measuring something representing speed, and using it for feedback. DC tach generators have a long tradition, but are ceding ground to rotary pulse generators and digital encoders. When measured speed drops below setpoint speed, the controller increases armature voltage to compensate, if speed is above setpoint it reduces armature voltage, and if measured speed equals setpoint it allows voltage output to remain unchanged.
Each feature adds complexity, but a 'true' motor controller also has a way to set minimum and maximum speed, to control acceleration and deceleration (accel/decel, which performs essentially what 'soft start/stop' does in your example), and some form of current limiting to prevent mechanical overload from blowing up the drive and/or overheating the motor.
The current measurement obtained on the 8A charger range with 1 kg load appears to be a mis-read (shown in red).
Likes marcophys
Oh yes, I will certainly be trying it :)
I have just tested the barrel (1.7Kg) @ 4A
Bizarrely it rotates at 52 rpm.
The expected rpm was 56.
This may be because it is not balanced (due to the exhaust).
The test weights were 'weight lifting' weights @ 1Kg each... so perfectly round.
Using the scientific methodology of just looking at it spinning... I think we are entering the working range.
Probably in the region of 30 rpm will be better.
I'll experiment with resistance.
I take your point regarding the complexities of a feedback system.
... but at this stage of the project it is always worthwhile examining options.
Anyway, I wanted to supply the test results as per requests.
This enables further input from the community.
Apart from that... it may be the case that one quickly understands the settings for different loads.
However... tomorrow I'm back on mechanical engineering (my primary domain).
I need to create a new drive shaft that is longer - the one I was using was to hand, but is 10mm too short.
I also must grommet the enclosure, and add flex.
Plus the turntable studs to locate the barrel and eliminate 'a blind hole', to allow full cylinder penetration (and facilitate air flow).
Vertical movement will be by hand :nb)
I'll try and design a simple 'centralisation rest'.
The problem is the robustness of the pressure lines - very numb and they exert their own pressure.
... having something to push against, central to the cylinder, is probably the minimum necessity.
However, I have numerous barrels to work with, before attempting 'the task' on my new top end.
Maybe tomorrow night, I'll have something to show for the work so far.
:smile:
Thank you very much for checking my figures.
My guess is that I have inadvertently swapped the figures between the 2kg and 1Kg loads.
If this is so, the table should read:
Load - RPM - Amps
8A delivers 10.9V motor load - 1 kg - 80 rpm - 2.4 A *
8A delivers 10.3V motor load - 2 kg - 68 rpm - 2.8 A *
* bold results swapped.
I'll run the tests again, after cleaning up the gearbox.
My next post will show the gearbox dismantled.
Motor Gearbox Examination
Lots of interesting discoveries made here.
I made a video, as it's easier to discuss each issue:
So the motor units were swapped.
This time, the shaft seal was included in the assembly.
Note the spring
The seal is from a water pump, has two seal faces, and apparently compresses the shaft seal, as the spring is compressed.
This, we discover, adds load to the motor.
The result is that the motor rpm has substantially slowed.
Clockwise = 34 rpm
anticlockwise = 68 rpm​
Is this just coincidence?
Very nice though, because by good fortune... so far, I have a two speed motor, and both speeds are where I want them to be.
Ahhhh!
Let's allow ourselves a brief glimpse of superstition, and suggest that this is karma :smile:
Testing The Motor @ Supply 13.5v No load (stated 8 Amps)
These tests seem to be inconsistent.
This may be due to my gauging of the median between high and low.
Also, the motor is getting hot.
But even RPM results jump a bit.
Perhaps the unit is bedding in... as also the seals.
Anyway... having done the testing, I include the results below.
We at least have the ballpark figures.
It may be better if I re-test the unit after giving it some work.
No Load
Clockwise = 34 rpm - 8.36 V - 3.95 A
anticlockwise = 68 rpm - 9.85 V - 2.84 A
Engine Barrel 1.7 Kg
Clockwise = 30 rpm - 8.25 V - 3.90 A
anticlockwise = 56 rpm - 9.45 V - 3 A
Weight 1 Kg
Clockwise = 32 rpm - 8.30 V - 3.95 A
anticlockwise = 64 rpm - 9.70 V - 2.98 A
Weight 2 Kg
Clockwise = 35 rpm - 8.38 V - 4 A
anticlockwise = 66 rpm - 9.58 V - 3.20 A
The development project has gone very well.
I removed a seal that I believed to be too tight... but the motor still remains protected by two seals.
After putting the turntable to work... it is clear that the motor is not under excess load... it sounds fine.
The 1.5 sq mm cable runs for approximately 10m.
This conveniently allowed my battery charger to remain in it's original position.
I didn't have a 'latching' reversible polarity switch - the window winder switch is 'hold to make contact', therefore:
The control panel was created using 3 x '3 pole' (light) switches, mounted on two 'cork backed dinner placement mats' (to provide screw depth).
2 switches were mounted side by side, with the inner and outer poles connected.
The third switch breaks the live feed.
The 2 switches controlling polarity reversal, require bridging (a bar, top and bottom, across the the switch interface).
The advantage of the large switch interface, is that they can be 'foot operable'.
It doesn't get better than that, as both hands are ensconced within 'operator gloves'.
The left foot controls the turntable... the right foot controls the ejection of the 'material surface modification media'
Results
Clockwise = 35 rpm - 6 V
Anticlockwise = 68 rpm - 7.80 V
These speeds tested well for the removal of the first few surface molecules (using very sharp micro particles).
I have yet to attempt any densification.
However, successfully completing the first phase, leaves me confident of final surface modification.
Further Tasks
Adding a fuse into the circuit.
The original fuse, provided with the motor is a straight 15 Amps (30mm x 6.3mm).
The presumption is that the original electrical engineers got it right.
... but such presumptions are always open to peer review.
From a theoretical perspective... is there an ideal position for the fuse?
Placing it close to the PSU seems logical, though that is 10m away from the motor.
Joining The switches
The switch actuator is rigid enough, but thin.
Rather than hot gluing two bars... I will add material on the underside of each actuator.
In this way, I can screw the bars in place.
This will enable easy dismantling, at some future moment.
So far so good... zero time wasted in sourcing components
In the video the gearmotor is noisier In one direction than the other. If you have it apart again, disengage the worm from the gear, and see if noise comes from the motor itself, or if it is (my guess) due to gearing.
Can't tell for sure if it is a fast or slow blow fuse (looks like a fast blow) but a 15A rated fuse at 12V will allow 180 watts of motor power for a considerable time.
During testing you had observed the motor beginning to run hot somewhere in the 35 watt ballpark, so 15A provides only wire protection, and not for motor overload. I'd try a 5A fuse. Installed at the power supply it will protect against a wiring short circuit as well as motor failure/overload.
Looking good!
Likes marcophys
  • #31
window motors aren't expected to see continuous duty...
Likes Asymptotic
  • #32
I will check the motor without worm drive.
I was wondering what is making it a two speed motor, depending on polarity.
I attempted to remove the motor outer casing from the spare motor, but even after heating the screws they weren't budging.
I'll come back to that operation.
Re the fuse
I found a BS1362 5A fuse.
I then opened the charger.
It's a West German Absaar Type 108 NE/D2 with a push button fuse.
However, the fuse has no data on it whatsoever, but T 25 F appears on the underside data sheet.
The Fuse is top left
Wired from the Ammeter to Output.
The fuse button is out and is on a spring.
I presume it must trip on heat.
Any thoughts?
Should I still install the BS1362 5A fuse?
Re motor duty
This is to be seen.
The motor isn't running continuously.
By necessity it is fully enclosed in plastic (as per the earlier photo).
It's a roomy enclosure, but heat will dissipate slowly through the plastic.
I could have it wired to the standard foot switch - but It would mean more stopping and starting.
In Use
It seems to be running freely without signs of protest.
I'm going to complete all the planned operations, and then run some more tests.
  • #33
That's interesting, and when you think about it they might have done it on purpose.
One way it's lifting the window which is a several pound load plus friction.
Other way it's lowering the window so runs unloaded.
To get same up and down speeds for aesthetics one would do something to slow unloaded "Down" speed to match loaded "Up" speed.
I've no idea what they did.
Perhaps some clever mechanical trick with friction in the worm drive; ME's are brilliant at such things
perhaps a third brush; a mundane EE trick
perhaps a few turns around the permanent field magnets to slightly aid or oppose them ?
Now you've got me curious - next one i find i'll take apart...
  • #34
I think that it must be electrical... it is almost perfectly twice or half speed.
Minor difference will probably come from increased friction one way:
This voltage was measured only a few inches from the motor at the end of approximately 10m of 1.5 sq mm cable
I've had another look at the screws holding the motor casing.
The problem is that I can't get a T bar in play due to the screw proximity to the casing.
That leaves the screw driver.
Also the screw heads are not hard.
Having already tried with heat, I can see that this would come down to 'drilling out'.
With so much to do, the motor must remain a mystery for the time being.
  • #35
marcophys said:
Re the fuse
Absaar may be calling the red buttoned device a fuse, but it actually is a push-to-reset circuit breaker wired in series with the charger DC output. Can't say what the "T 25 F" marking means. 25A seems a high current rating for this purpose; Absaar type 108 charging output is 11 amps, and a 15A breaker sounds about right. If the charger is operational with the button out then either it comes out farther when in the tripped state, or it is tripped, but the breaker contacts are welded together.
Many circuit breakers are thermal-magnetic in nature. Long-duration, marginal overloads cause trips due to thermal effects while magnetic principles are used to quickly clear severe overloads and short circuits.
Is the BS1362, 5A fuse in the line cord plug? Or are you asking whether one of these are appropriately rated to provide motor protection?
Likes marcophys
  • #36
RE T 25 F
I found this catalogue:
http://www.sensata.com/download/klixon-circuit-breaker-thermal-catalog.pdf
On page 4 it shows all the breakers with very similar red buttons.
On page 6 & 7 there are the specs showing temperature rating at 25 deg C
Perhaps therefore: T (temp) 25 F (fuse)
Re potentially welded together
I note that the Klixon buttons are a similar distance out.
This isn't hard data, but...
Certainly my fuse button seems to be out a good distance (6mm).
I have spoken to Absaar, but the charger is pre the experience of the technician.
So I've sent him an email with the photos etc.
Yes it fits in the sprung in-line fuse holder.
It's a touch shorter than the original, but the spring handles it.
  • #37
hmmm
Automotive fuses will be rated just 32 volts
Check , it should be written on one end.
Don't rely on an automotive fuse to interrupt line voltage for it might or might not do it. Get a proper 250 volt rated fuse. Any good hardware store should have them , or look in junk electronics (dead PC power supply?) .
  • #38
jim hardy said:
hmmm
It is suggested that the auto fuse be replaced by the BS1362, 5A fuse in the line cord plug.
The spring tension is fine.
The original auto fuse was rated at 15A.
  • #39
Ahhh, thanks for clarification.
I see BSC1362 (a new term to me) is a British standard for line fuses !
http://www.cooperindustries.com/content/dam/public/bussmann/Electrical/Resources/product-datasheets-a/Bus_Ele_DS_2042_TDC180.pdf
Wikipedia:
https://en.wikipedia.org/wiki/AC_power_plugs_and_sockets:_British_and_related_types
BS 1363, 13 A plugs socket-outlets adaptors and connection units is a British Standard which specifies the most common type of single-phase AC power plugs and sockets that are used in the United Kingdom.
Learn something every day... Thanks !
old jim
  • #40
Ha!
Nice data sheet find... good share.
When I searched, the BS site wanted £65 to view the data sheet.
So annoying, particularly as it's a common or garden 'gold standard' that was created in 1947, and modded to include the 5A into the standard in 1973.
As an aside... I see that you've successfully avoided the global debate about BS1363, as to whether this is the ultimate 'plug & socket' connector system (it's best avoided)..
I note that 'fuse users' (everybody) are now advised to weigh the fuses before use to confirm authenticity.
Anything less than 2.2g should be discarded.
Mine is 2.4g :cool:
http://www.bs1363.org.uk/DTI_warning_on_Counterfeit_Fuses_web.pdf
Here's a link to a counterfeit BS1362 fuse test page, with a nice video at the bottom, showing a fake fuse exploding on short circuit.
http://www.pat-testing-training.net/articles/fake-fuses.php
Or if you really want to go anal, and see how prime time TV educates the public on fuses... here is the first 10 minutes of a program devoted purely to the the subject of fuses.
I love it!... it's all down to the sand.
Hence why I proclaimed that I'd found a BS1362 5A fuse.
I thought oooh... that's a good one :biggrin:
Likes jim hardy
  • #41
I'm a believer in sand . It's the arc-quenching medium in fast acting semiconductor fuses like Shawmut 101's.
I've dissected many a fuse for post-mortem forensics on electrical failures ...
Counterfeit fuses ? OMG thanks for the head-up.
  • #42
I know... it's horrifying.
... and you can no longer rely on print quality as the flag.
Previously everything about them (counterfeits) were crap.
... but now they have the printing to perfection, and they are flooding the market.
It's not the cost of the sand... it's the fact that this entire element of the production line isn't included.
Take away 'sand management & implementation' and everything becomes as easy as a wire , two caps, and a printed enclosure.
... and within that remaining structure... anything goes.
... and apart from electrical failure scenarios...it impacts on quality producers and jobs...
So it's good that TV producers are kicking out these warnings at prime viewing hours.
... Anyway... I've completed surface densification today.
  • #43
Heaven forbid one of those fuses winds up in somebody's multimeter.
This is video of the explosion that might result (don't worry it's a demonstration filmed with a dummy)
whiteout from fireball lasts 'til 22 seconds
  • #44
Densification left a polished finish.
Static densification doesn't.
1st phase surface removal media is extremely sharp.
Therefore, on impact a cut occurs, even when the iron surface is passing at the speeds discussed.
Round ceramic dust media must be delivering a glancing blow.
In fact, this is as predicted, though I didn't consider that a polished surface would be the result.
I can get the speed down to 29 rpm @ 5.3V 4.7A (using the slow charge switch on the charger).
35 rpm @ 6V 5.1A (using fast charge switch)
(It looks like that 5A fuse is too light)
If I drop the voltage again, by say by increasing the supply cable length, the Amps will increase again.
Is this problematic to the motor?
  • #45
I added 8m of cable:
26 RPM 4.4V 4.5A
So the volts dropped and the amps dropped.
I expected the amps to rise.
I have to presume that the extension crocodile leads shouldn't be used.
This last measurement was taken with the meter probes screwed into connector blocks.
What I'll do is add another 8m of cable - it's a 4 wire cable - I can simply solder the ends).
I'll measure again using the same system.
This way we should get a genuine difference between the two.
  • #46
A further 8m cable... so approximately 26m in total.
21 rpm 3.8V 4.35A.
The motor seems to be rotating fine.
The volts are up and down... so the reading is best median.
I've started, so I'll continue.
The goal is to get it to 10 RPM.
  • #47
This is better.
We have 45m of 1.5 sq mm cable.
With the barrel mounted on the turntable:
11.5 RPM 2.8 V 4 A​
The motor seems to turn okayish... but there is a tight spot, so it slows and speeds up within one revolution.
... but this is to be expected.
The only question is whether the motor can function at this setting, on an ongoing basis.
I will remove the enclosure cover, and simply touch the motor to judge whether it is getting hot.
  • #48
Ha ha!
The big news that we've been waiting for...
I ran the motor continuously for 10 minutes, and was able to hold my hand on the motor.
It was getting hotter constantly, but thinking of shower temperatures, my guess is that after 10 minutes it reached around 45 - 50 deg C.
To 5 minutes it had barely warmed.
I don't know what the fail point will be, nor the cool down period, but it definitely seems workable.
When I think of typical motors that run for say an hour... you can't even touch them because they are so hot.
Does anybody have any thoughts on this area?
I need to test densification at the new speed, but knowing the speed that one's hand moves over clean iron, I am very confident of success.
11.5 RPM is a crawling pace.
I'll confirm this.
Other exciting news
The enclosure contained ceramic media (what?)
I once saw a doc on the development of a new torpedo.
The camera crew were there for the first trial in the test pool.
It sank!
(I scoffed)
The journalist, in horror, said "but it sank".
The prototype engineer was totally unphased... he said "they all do, the first time".
I take back my scoffing.
The enclosure was unpacked from its polythene wrap - a new stock item.
But the gasket had parted in one place.
Yet only one place - and with no outlet... why would the ceramic media be looking to ingress?
The answer is of course positive air pressure.
While the filter is the cost of a small bungalow... it struggles to cope at the 'micro particle level'... so extraction is advised to be restricted
... otherwise the media (the cost of the car in the garage) will be extracted through the filter... and we don't want that.
Hence, there is a slight positive pressure build up, sufficient to find any failings in the enclosure system.
Thankfully, due to the weight of the dust, and the lack of air movement in the enclosure... it looks like the particles have entered the enclosure and for the most part dropped (there was no dusting on the motor itself).
However, this is a cautionary tale for electrical engineers.
The moral of the story is to check the gasket, even when dealing with a new enclosure.
Just the daily differing air pressures might cause an enclosure to breathe.
Then imagine the motor getting warm, heating and expanding the air... forcing some out through the shaft seal?
I'm not sure... the seals are tight.
... but it does raise the question of 'to breathe or not to breathe'?
The ideal must be a diaphragm - say between the lid and box.
Then you could have a hole in the lid (facing down).
The air pressure would be equalised by the diaphragm, ensuring that there would be no external or internal pressure on the shaft seals.
Eliminating the cable
Prior to moving to a PWM system... can the cable be simply replaced with a resistance?
If so... what sort of values should be in the ballpark?
Note: just seen a typo in the previous post... it should read 35m of 1.5 sq mm cable.
  • #49
Found a dimmer switch rated 250V AC 40 - 250W
Can this be used?
  • #50
Diaphragm made, exactly as first suggested.
I put a 3.5mm breather in the furthest corner from the gear box.
I then blew in.
... nothing at first (and I was thinking what?)... and then that was it; the cavity was filled and pressurised.
So the enclosure can breath, while the motor remains sealed.
Warm air or cold air, the diaphragm will absorb the pressure differential.
This should prevent any ingress of media between the seals and drive shaft.
