Dependent voltage source, find max. power to load in circuit & R(Th)
In summary: Still stuck on how to get VTh too though.In summary, removing the resistor RL from the circuit results in a node equation with a potential of Vab.
Color_of_Cyan
386
http://imageshack.us/a/img831/2617/homeworkprobsg213.jpg Find the load RL that will result in maximum power delivered to the load of the circuit. Also determine Pmax delivered
V = IR, KVL, KCL,
voltage division, current division
Thevenin procedures,Pmax to a load resistor = (V Thevenin)2/(4 Rload)R(Th) = R(load) ??
No idea what to do regarding dependent voltage source.
If I try to silence it with the 6V to find R(Th) I would get
[ (1/4) + (1/6) ]-1 = 2.4Ω but that isn't right.And then I have no idea how I would find VTh afterwards either
(although I know it would typically be the voltage where a is with the 4 ohm load resistor cut out of the circuit) Any tips?
The 4Ω resistor is not the load resistor, it's part of the network "behind" the load. RL is the load resistor. The 4Ω resistor stays put. Vth would be the open circuit voltage with RL removed.
Try removing the resistor RL and writing a node equation for node a. Solve for Va.
I know the 4Ω wasn't part of the load (which is why I did 1/6 + 1/4 for parallel to try to find RTh, but to no avail)
If I take out the load, can I put 6 and 4 in series, even though there's a dependent voltage source?
With the load cut out and the above statement, all I could think of for it (and nodal equations) are:
Req (non thevenin) = 10Ω
Va = 2Vab + 6V
I = ( 6V + 2Vab )/10Ω
but I'm not sure
If they are in series, then they are in series. No argument. BUT. What are you trying to accomplish by putting them in series? You won't find the Thevenin resistance by considering the actual resistances alone; active sources can behave in ways that "mimic" resistances (even negative resistances!), so one needs to be a bit more clever when looking for the Thevenin resistance of a network with active sources (more below*).
Va = 2Vab + 6V
but I'm not sure
For a nodal equation I'd expect you to write a nodal equation for the node associated with terminal a (with RL removed), thus writing a KCL equation at node a that includes the potential at node a. Note that the potential at node a is identical to Vab so long as node b is the reference node.
With this nodal equation you should be able to determine the potential Vab. This will be the Thevenin voltage.
*note: The Thevenin resistance of a network can also be found by taking the ratio of the Thevenin voltage (open circuit voltage) to the short circuit current, also known as the Norton current. If you determine Vth and IN, then Rth = Vth/IN. The short circuit current should be easy to determine, since shorting the output pins Vab to zero.
Okay. Would i regard the 2Vab source though as the same kind of voltage source when doing nodal equations?
Finding VTh would still be a challenge for me for the same reason (because of that 2vab source)
And to find the Norton current as you say wouldn't the 4 ohm resistance be shorted too? It would still also leave the 2Vab current source too, wouldn't it?
And since Vab would be 0 then 2Vab would be 0 too, right?
So would I Norton just be 6v / 6 ohms ?
(1 amp?)
It seems too easy to be true. Still stuck on how to get VTh too though.
Yes. It is a voltage source. Write it in as "2Vab". The node voltage happens to also be Vab.
It's just another voltage term in the equation...
(1 amp?)
Yes, the 4Ω resistor gets shorted, and yes, as a result Vab is zero. Nothing wrong with short circuit current being 1 amp, even if it is easy to find :smile:
For Vth, write the nodal equation and solve for Vab.
You could also try writing a mesh equation for the left mesh, which is the only mesh left if you remove Rload. Once you have the current in that mesh (call the current I1), then Vab is just 4*I1 = Vth.
So would one equation be
Vab = 6V - 2Vab
by any chance?I don't have to worry about current right now for this either, right?
You do have to worry about current.
Write a mesh equation starting at the bottom left of the left hand mesh, and going clockwise.
Start out like this:
-6 volts - 6Ω*I1 amps - 2*Vab volts...= 0
Substitute Vab = 4*I1
and finish it up.
Vab = 6V - 2Vab
by any chance?
That is neither a nodal equation nor a mesh equation for the circuit. The current is important, as it causes potential drops across the resistances.
Pretend that the dependent voltage source is just another voltage source, but use "2Vab" for its value when writing the node equation (or mesh equation if you wish to go that route).
I have been assuming that you are familiar with writing node equations (or mesh equations). If you aren't, it would be helpful to know what circuit analysis techniques you are familiar with.
I don't think I've really done either before with 1 loop before like this (or just not enough with actual sources like this either).
To be honest, I'm not even sure how the potential will stack up with the dependent source either (since there's a resistor "behind" the 2Vab and another "in front")
I'll try though:
6V/6Ω = (6V + 2Va)/4Ω ?(I know at least the current will be the same in the resistors because they're in series)
No, that's not right.
In nodal analysis you assume that each node has some potential as represented by a variable. In this case there's one independent node and we give it the variable "Va". We also assume some common reference node, and here we choose b to be the zero reference.
Writing a node equation consists of doing a KCL sum of currents at the node. Usually one chooses to write the sum assuming that all currents are entering or all currents are leaving the node, so the sum will be zero. The currents for individual branches are determined by way of a KVL path walk of the branch given the two potentials at either end of the branch; assume current I is flowing in the branch in the assumed direction and sum the potential changes along the path. Solve for I and that's the term for that branch in the nodal equation.
In this case the node potential for the node of interest is taken to be Va, and at the other end of the branches it's 0 (the reference node). So, for example, if we want the term for the current leaving node though the 4Ω resistor branch we'd write the KVL: Va - I*4Ω = 0, so that I = (Va - 0)/4Ω, or simply Va/4Ω, where I is the current for that branch. Terms for each branch connected to the node should be written, the sum of terms being zero.
Can you write the term for the current leaving the node via the 6Ω resistor branch? The potential starts at Va, drops by 2Va, then by I*6Ω, then by 6V where it finally reaches the 0V potential of the reference node.
Sorry for getting back to this so late.
I honestly don't think I've seen anything like that before / yet or had no idea you could do it this way (for nodal). It gets confusing at times, and you make it look so easy.
It's helpful though, so thanks for showing me. So would the other equation then be
Va - 2Va - I*6Ω - 6V = 0 ? (I just tried setting this equation equal to I = Va / 4Ω though and then solving for Va, plugging in everything but the answer was still wrong).
I'm surprised that your course would introduce dependent sources before thoroughly covering nodal and mesh analysis techniques.
Yes. Solve it for I also to yield the current term for that branch.
Note that these I's are (usually) different for different branches -- the I's that we're using here are just "temporary variables" used as an aid to help you find the current terms for each branch. After some practice you will be able to write down the branch current terms by inspection without having to use these "I" placeholders to construct the expression via KVL walk.
Yes, that's because I is not an actual variable to be used here; The two I's represent the branch current expressions (Maybe you want to give them different names, I1 and I2, just to make it clear that they represent different current terms). I'm sorry, I should have clarified this before: it's the expressions for the individual branch currents that you want to find, since they form the terms of the node equation you wish to construct. Introducing I as a temporary variable in the KVL walk for a branch is meant to help you solve for the branch current expressions in a (hopefully) familiar way.
Sum the two current terms and set it to zero (KCL for the node). Then solve for Va.
So, you pretty much always have to do more different / careful circuit techniques (ie nodal, mesh) when you deal with a dependent source then, right? I thought the currents would just directly be the same since all the elements are in series with the load cut out. I couldn't see that Va = 4Ω*(current through 4Ω) either at the beginning either because of the dependent voltage source, yet it has to still do with finding Va in the first place. So I guess that's something to keep in mind next time too.
Seems like I have the correct answer too now though, thanks (although signs are different).
Rth = 12 ohms, Va = -12V
and Pmax = 3W.
You bring whatever machinery is required to bear; sometimes Ohm's law will suffice. There's no hard and fast rule about what MUST be used. Use what you're familiar with that gets the job done.
I suggested nodal analysis because it would directly give you Va, which is Vth, by forming and solving a single equation. You could also have done KVL around the loop to find the current, then calculated Vth as the voltage drop caused by that current passing through the 4Ω resistor.
and Pmax = 3W.
Looks like something must've happened to a sign when you wrote/solved the node equation; you should get +12V as a result.
Here was the work
Va - I1*4Ω = 0
I1 = Va / 4ΩVa - 2Va - I2*6Ω - 6V = 0
I2*6Ω = Va - 2Va - 6V
I2 = (Va/6Ω) - (Va/3Ω) - 1AI1 + I2 = 0
Va/4Ω + Va/6Ω - Va/3 - 1A = 0
Va(1/4 + 1/6 + 1/3) = 1A
Va(1/4 - 1/3) = 1A
Va(3/12 - 4/12) = 1A
Va(-1/12) = 1A
Va = V Th = -12V
I Nort= 1ARTh = V Th / I Nort
Would RTh actually be negative too? (Or did I do something wrong again?)
Color_of_Cyan said:
Here was the work
Va - I1*4Ω = 0
I1 = Va / 4Ω
I1 + I2 = 0
Va(1/4 + 1/6 + 1/3) = 1A <--- How did -Va/3 become +Va/3 ?
Va(1/4 - 1/3) = 1A
Va(-1/12) = 1A
Va = V Th = -12V
I Nort= 1A
RTh = V Th / I Nort
Rth should be positive in this problem.
That was a typo, heh.
I fixed it in the next line though (subtracted 2/6 from 1/6). The answer for Vth isn't given though, just RTh and the power (and both were positive as you say)
Maybe he just meant absolute value or something? Even though you can also have negative resistance?
Not sure what else to do there, but again, thanks.
Color_of_Cyan said:
Here was the work
Va - I1*4Ω = 0
I1 = Va / 4Ω
I1 + I2 = 0
Va(1/4 - 1/3) = 1A <-- 1/6 - 1/3 ≠ -1/3
Va(-1/12) = 1A
Va = V Th = -12V
I Nort= 1A
RTh = V Th / I Nort
Oops. Missed the math error on the next line.
Okay I did miss that. Weird, lucky it still -1/12 the other time then
(1/4 - 1/6) = 2/24 = 1/12
Va(1/12) = 1A
Va = 12V now
my bad,
Everything's right now, thanks again.
Related to Dependent voltage source, find max. power to load in circuit & R(Th)
What is a dependent voltage source?
A dependent voltage source is an element in an electrical circuit that provides a voltage output based on the voltage or current of another element in the circuit.
How do you find the maximum power to load in a circuit?
The maximum power to load in a circuit can be found by using the maximum power transfer theorem, which states that the maximum power is transferred from a source to a load when the source resistance is equal to the load resistance.
What is R(Th) in relation to a dependent voltage source?
R(Th) is the Thevenin resistance of a circuit, which is the equivalent resistance of the circuit when all independent sources are turned off and replaced with their internal resistances. It is used to determine the maximum power transfer from a dependent voltage source to a load.
How do you calculate R(Th) in a circuit with a dependent voltage source?
To calculate R(Th) in a circuit with a dependent voltage source, you will first need to simplify the circuit by replacing the dependent source with its equivalent voltage or current value. Then, you can use standard circuit analysis techniques to determine the Thevenin resistance of the circuit.
What factors can affect the maximum power transfer in a circuit with a dependent voltage source?
The maximum power transfer in a circuit with a dependent voltage source can be affected by the values of the source and load resistances, as well as the type and characteristics of the dependent source itself. Additionally, the presence of other independent sources in the circuit can also impact the maximum power transfer.
