Design a clipper circuit with a specific output
The discussion revolves around designing a clipper circuit, focusing on the configuration of diodes and the calculation of resistor values to achieve a specific output voltage gain. Participants explore the implications of the gain value of 0.95 and the characteristics of the input waveform required for the circuit design.
  • Homework-related
  • Some participants propose using two diodes in opposite directions with a DC battery to create the clipper circuit.
  • There is a discussion about the meaning of a gain of 0.95, with one participant explaining it relates to the voltage divider formed by the series resistor and load resistor.
  • Participants calculate the required resistor value (R = 52.63 ohms) to achieve the desired output voltage.
  • Questions arise regarding the input waveform, with a consensus that a sine wave is to be used, but uncertainty exists about its amplitude.
  • One participant suggests that the output will be a clipped version of the input waveform, while another clarifies that the output waveform clips at +/-3V.
  • There is a discussion about whether the input waveform needs to be drawn in the design, with participants agreeing that the input can be any waveform as long as it exceeds the clipping level.
Participants generally agree on the configuration of the clipper circuit and the calculations involved, but there remains some uncertainty regarding the specifics of the input waveform and its amplitude. Multiple views on how to represent the input and output waveforms are present.
Participants note that the input waveform can vary, and the clipping behavior will depend on the amplitude relative to the clipping level. The exact requirements of the homework assignment regarding the input waveform are not fully detailed.
Hassan Raafat
Clippers equations
I knew that we will put a two diodes( with a dc battery {2.3 V} series) parallel to each other in opposite directions .. but what meant by gain is 0.95 ?
Hassan Raafat said:
Clippers equations
It means that the voltage divider that you form with your series resistor and the load resistor should not drop more than 5% of the input voltage when the diodes are not conducting. Can you show us your solution circuit now? :smile:
http://blob:https%3A//www.physicsforums.com/e4a89897-2c3c-46b3-8433-735549d386cb
Hassan Raafat said:
Good! Now you just have to calculate the input resistor value so that the output voltage is 0.95 * Vin...
Camera is not good , I can't upload complete solution but R has a value R=52.63
Can you show your equations that you used to calculate this value? It looks about right, but it would be good to see how you got it. Just type it in here... Thanks.
http://20160325_192231.png
Yeah, the pictures are not showing up. Can you just type it with text into the forum window?
Vout = ( 1k / (1k+R) ) * Vin
Vout / Vin = 1k / (1k+R)
0.95 = 1000 / (1000+R)
R = 52.63 ohm
R = 52.63 ohm
Great! :smile:
Thanks a lot , Berkeman ... You are great :)
but I still have a question what is the waveform of input voltage ?
Oh, that wasn't part of what you posted in Post #1. The output waveform will just be a clipped version (and 95% of) the input waveform. What kind of input waveform are you supposed to use? Sine wave? Ramp?
sine wave
Hassan Raafat said:
sine wave
Of what amplitude? You should be able to draw the input and output waveforms...
that means that the output will be a sine wave with a peak equals (100/95) * 3 , right ?
Not exactly. The gain Vo/Vi = 0.95, and the Vo waveform clips at +/-3V.
Am I supposed to draw input in design circuits ?
And how I determine output without knowing what is the input of circuit ?
You draw the input sine wave with some amplitude (say, +/- 5V), and then draw the output waveform which is 0.95 as big, and is clipped at +/- 3V.
One way to do it is in Excel, but you can do it by hand as well. What is the exact wording of that part of this homework problem?
Design it meant to determine value of elements in the circuit if V,I are both known
You don't need to know much about input Vin. If Vin at any moment exceeds the circuit's clipping level then the output waveform will be clipped, and at those times when Vin does not reach the circuit's clipping level then there will be no clipping of the waveform.
Vin can be any waveform and the clipper will still operate. It is often convenient to illustrate the operation of a clipper using a sinewave, but you could use a triangular wave, or even random noise.
Your assignment asks you to use a sinewave input. Just choose its amplitude to be whatever is needed to produce some clipping, and sketch what the corresponding output will look like.
Thanks Very much NascentOxygen , I realized that shape of wave doesn't matter . :))
  • · Replies 19 ·
  • · Replies 23 ·
9K
  • · Replies 45 ·
10K
