Determin the magnitude of the net electric field of three point charges
The discussion revolves around calculating the net electric field at point P due to three point charges, with q1 known and q2 unknown. The net electric field at P is directed entirely in the negative y-direction, indicating that contributions from other directions must cancel out. Participants express confusion regarding the presence of a third charge and the role of point P, questioning whether it represents a charge or merely a location. There is a suggestion to use the electric field equation E=Q/4∏ε0r² to derive values for the unknown charges based on the known direction of the net electric field. Clarification is needed on the configuration of the charges and the assumptions regarding point P.
Ruth_1392
There are three point charges, q1 has a magnitude of 3.00mC (the sign is not known) and is 5.0cm away from P and 13.0 cm away from q2. P is 12.0cm away from q2 and the three points form a triangle. The net electric field at point P is entirely in the negative y-direction. The charge for q2 is not known.
Determine the magnitude of the net electric field.
E=Q/4∏ε0r2
I think you have to use the equation above and then add the 3 values together, but I don't know how to calculate E when I'm only given the value for q1 and none of the other points.
If you know the net electric field at p is only in one direction, the sum of the contributions in all other directions at point p must be zero. Try writing the total E-field in different directions at point p (sum the contributions from each charge) and set them equal to zero for all the cases but the y-dir. My guess is you will have a solvable system of equations from which you can get the charge values and the y-dir field at p.
For part a) I had to: Sketch the correct force configuration and work out the signs for the
charges q1 and q2. Do I use my answer for a) in this part?
Thanks
is the third charge at P?? Nothing is mentioned about the third charge? What three points form a triangle? If the problem is referring to point P, charge1 and charge 2 all this says is that they are not along a line. Where is charge 3?
The question had a picture and P, q1 and q2 formed a triangle. Does the question only use q1 and q2? I'm not too sure what P is.
The problem says three charges but only talks about two charges and point P. Electric field is defined as a force per unit charge but the problem isn't clear to me. Is there a unit charge at point P that we're supposed to assume? See if something is missing.
