Determination of delivery pressure from pump
To determine the delivery pressure from a centrifugal pump with a 2" pipeline, the pressure gauge reading of 0.6-0.8 Kg/cm² is lower than expected, while blocking the line shows 3.5-4 Kg/cm². The system involves approximately 5 meters of piping, with 80 spray nozzles rated at 2 Bar @ 10 LPM, leading to a calculated total flow requirement of 800 LPM at about 2 Kg/cm². To select a pump that consistently delivers at 3 Kg/cm², it is essential to plot the pump curve against the nozzle flow curve to identify the pump's maximum delivery rate. A schematic diagram detailing pipe dimensions, elevations, and fluid characteristics is crucial for accurate assessment and selection.
kunalvanjare
We want to know how can we determine the pressure of the liquid at the delivery end of the pump. We have a centrifugal pump and a 2" pipeline at the delivery end. Pump delivery performance as per catalog is 510LPM @20 mtr head to 348LPM @36mtr head.
The delivery pipe is connected to a manifold on which spray nozzles are connected around 70 Nos.
The total length of pipe from the pump outlet to the spray manifold will be approx 5 metres of which 1.5mtr is vertical & remaining horizontal.
We have mounted a pressure gauge on the line which gives a constant reading of 0.6-0.8 Kg/cm2 which is lower is lower than our expectations from a 5HP pump.
When we block the line just before the manifold, the gauge shows a reading of 3.5-4 kg/cm2.
Kindly help us determine the process of finding out the pressure in the line.
Also, If I have to select a pump that constantly delivers liquid at 3 Kg/Cm2, how do I go about the selection?
We need a system diagram that shows length and diameter of the piping, and elevations of the pressure gauge and the free surface of whatever you are pumping from. Also, what is the liquid? If not water, we need specific gravity and viscosity. If water, what is the temperature? What is the make and model number of the spray nozzles, or their rated pressure vs flow rate.
Likes russ_watters
Thanks for the reply. I have enclosed a schematic of the process with relevant dimensions.
In brief,
Diameter of the pipe - 50mm or 2"
Elevation of pressure gauge from ground - 1700mm
Length of pipe - mentioned in diagram
Liquid - Water
Temperature - 60-70 degree Celsius
Nozzle Rated pressure - 2 Bar @ 10 LPM
Total no. of nozzles - Approx 80
The pump characteristics are also enclosed in an image. The one marked in red is the pump I am using.
Thanks.
Some quick calculations: 80 nozzles X 10 LPM = 800 LPM at 2 bar = about 2 kg/cm^2.
You can take it from here with the following suggestions:
1) Plot the pump curve (hand sketch is good enough) with flow on the horizontal axis and TDH (head) on the vertical axis.
2) Nozzle flow is proportional to the square root of the pressure. Plot the nozzle flow curve on the pump curve.
Likes russ_watters
What is the pump's maximum delivery rate regardless of head?
Your question, and several other questions that you have not yet thought of, will be answered when you draw the pump curve, and add the nozzle flow curve to it. Post the curves here if you still have questions.
Likes Asymptotic
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
