Determine a formula for the acceleration of each block
The discussion revolves around determining the acceleration of two blocks connected by a cord on an incline, focusing on different friction coefficients. In scenarios where the friction coefficient of the first block is less than that of the second (μ1 < μ2), the blocks move together, resulting in equal accelerations. Conversely, if the first block has a higher friction coefficient (μ1 > μ2), the tension in the cord becomes negative, indicating no tension exists. The equations governing the system yield two unknowns (acceleration and tension) under these conditions, simplifying the problem. Ultimately, understanding the relationship between friction and tension is crucial for solving the motion of the blocks.
endeavor
For two blocks, connected by a cord and sliding down the incline shown in the figure, describe the motion (a) if \mu_1 &lt; \mu_2, and (b) if \mu_1 &gt; \mu_2. (c) Determine a formula for the acceleration of each block and the tension FT in teh cord in terms of m1, m2, and \theta; interpret your results in light of your answers to (a) and (b).
http://img407.imageshack.us/img407/5930/chp5pro22nd5.th.png
I need help on part c.
I got two equations in three unknowns (T, a_1, a_2), and I don't know what to do:
m_1 g \sin \theta - F_{fk1} - T = m_1 a_1
T + m_2 g \sin \theta - F_{fk2} = m_2 a_2
F_{fk1} = \mu_1 N_1
F_{fk2} = \mu_2 N_2
F_{fk1} = \mu_1 N_1
F_{fk2} = \mu_2 N_2
If the blocks move together with tension in the cord, their accelerations are equal. What if the tension in the cord is negative under this assumption?
Oh I see...
So under the conditions of part (a), a1 = a2. And under the conditions of part (b), there is no tension. So now there's only two unknowns in two equations.
endeavor said:
Oh I see...
Yes, that is correct.
