Determine the linear acceleration of the two masses
The problem involves an Atwood's Machine with two masses connected by a cord over a pulley. The objective is to determine the linear acceleration of the masses and the angular acceleration of the pulley, which is a solid cylinder. The discussion centers around applying Newton's laws and energy conservation principles.
  • Participants discuss drawing free body diagrams for the masses and the pulley to apply Newton's second law. There are attempts to calculate forces and torques, with some participants suggesting energy methods for solving the problem. Questions arise about the role of the pulley's mass and its contribution to the system's dynamics.
The discussion is active, with various approaches being explored, including force analysis and energy methods. Some participants have provided calculations and diagrams, while others are questioning the assumptions regarding the pulley's mass and its effects on the system.
Participants are navigating the complexities of the problem, including the implications of the pulley's mass and the need for clarity in applying Newton's laws and energy conservation. There is an emphasis on not using numerical values prematurely in forming equations.
Crystal
Poster has been warned about posting with no effort shown
Two masses, mA = 40.0 kg and mB = 55.0 kg, are connected by a massless cord that passes
over a pulley that is free to rotate about a fixed axis. This device is known as an
Atwood’s Machine. The pulley is a solid cylinder of radius R = 0.360 m and mass of 7.50
kg.
1. Determine the linear acceleration of the two masses
2. Determine the angular acceleration of the pulley
a=atan+ar
not sure how to start, any hints would be great
Welcome to PF:)
First draw free body diagrams of ##m_{a}##,##m_{B}## and pulley separately.
Try to make equations by using Newton's second law of motion and rotation.
Satvik Pandey said:
Welcome to PF:)
for Ma I got 9.8*40=392
Mb 9.8*55=539
making the total force is 147.
I also know that to find net torque of the pulley its =mratan.
What should I attempt next?
There's a way to solve the problem 'by energies', equating the PE of the system with its total KE 'after the fall', giving that fall some arbitrary value. You should remember that the total KE of this system is the sum of its linear kinetic energy and its rotating kinetic energy...
Mb 9.8*55=539
I have made free body diagrams for you
Can you form equations using Newton's second law of motion and rotation.
Just use variables as shown in diagram. Do not put the numerical value right now.
so
fnet = total mass * acceleration
fnet = the sum of all forces on both objects
making it
total mass * linear acceleration = sum of all forces
linear acceleration = 9.8(-40+55+7.5)/(40+55+7.5)
linear acceleration = 2.15rad/s^2
The pulley does not fall not rise or fall, and its mass should not be added to the other two masses. And its weight plays no role...
The contribution of the pulley is to decelerate the masses absorbing a part of the variation of their PE in the form of rotational KE. That's why I pointed out that the problem could be solved 'by energies', equating the loss of PE of the system with the increase of linear KE plus rotational KE...
so use the formula 1/2mv^2+1/2Iw^2?
  • · Replies 18 ·
  • · Replies 66 ·
