Difference Between Phase and Time-Delay
  • Thread starter Thread starter frenzal_dude
    Difference Phase
Phase and time-delay can be converted into one another, with a time delay representing a negative temporal shift along the time axis. The example provided demonstrates that a phase shift of π/2 corresponds to a time delay of 1/(4B). The correct transformation shows that a time delay results in a phase change in the sinusoidal function. This relationship holds true as long as the shifts are linear. Thus, a phase change indeed has a corresponding time delay and vice versa.
frenzal_dude
Hi,
I understand what phase and time-delay are, but can they be converted from one to the other?
For example is the working out below correct?:
Sin(2πBt + \frac{π}{2}) = Sin(2πB(t + \frac{1}{4B}))
So basically a time delay of (t + \frac{1}{4B}) = a phase of \frac{π}{2} ?
frenzal_dude said:
Hi,
You have the right idea, but you have just made a small conceptual error). A time delay is equivalent to a negative temporal shift; or a translation in the positive direction along the time axis. If your original signal \sin(2\pi B t), then after a time delay of 1/(4B), your new signal will be
\sin\left(2\pi B\left[t-\frac{1}{4B}\right]\right) = \sin\left(2\pi Bt - \frac{\pi}{2}\right)
Does that make sense?
Thanks for your help, yeh it makes sense.
So basically it's true that a phase change has a corresponding time delay and vice versa?
Yes, assuming the shift is linear, i.e. t\mapsto t+\text{const.} and \omega\mapsto \omega+\text{const.}.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
