Distance for charge to travel through magnetic field
To determine the distance a charge travels through a magnetic field after being accelerated between charged plates, the mass of the charge (proton or electron) and the magnetic field strength are crucial. The charge will follow a curved path due to the Lorentz force, with the radius of the arc calculable using the formula radius = mv / |q|B, where m is mass, v is velocity, q is charge, and B is the magnetic field strength. The discussion highlights the need to calculate the vertical displacement of the charge to find the exit point from the magnetic field. A triangle can be drawn to visualize the exit distance based on this arc. Understanding these principles is essential for solving the problem accurately.
bluedevil09
In the diagram below, an elementary charge (either an electron or a proton, you decide) is accelerated between two charged plates into a magnetic field. The mass of the proton = 1.67x10^-27 kg. The mass of an electron = 9.11x10^-31 kg.
D. Find the distance from the entrance point to where the charge
I know that the electron is going to arc up while going through the field, but I don't know how to find how much it arcs up and therefore the point at which it exits. FYI, the field is 10cm x 10cm, and starts right after the proton moves through the hole in the plate. How do I figure it out from here? Is there a way to figure out how far up the proton will move vertically? If so, I could draw a triangle and find the distance to where it exits
If the velocity is perpendicular to the magnetic field you can find the radius of the arc by mv / |q|B
Not sure if this is the right approach but it might help.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
