Doppler effect wavelength from car
A car traveling at 30 m/s emits a siren frequency of 600 Hz, with sound velocity in air at 330 m/s. The wavelength of sound directly in front of the car is calculated to be 0.5 m, while the wavelength behind the car is 0.6 m. The Doppler effect equations are applied to determine the frequency heard by a stationary observer, utilizing the sound velocity and the car's speed. The discussion concludes with the user confirming their calculations and understanding of the concepts involved.
matt_crouch
A car is traveling at 30m/s in still air. the frequency of the siren on the car is 600hz. The velocity of sound in still air is 330 m/s. what is the wavelength of the sound waves
a)directly in front of the car
b)directly behind the car
What is the frequency of the sound heard by a stationary observer
c)directly in front of the car
d)directly behind the car
FD=CD/Cs *Fs
Im not really sure where to start if someone could point me in the right direction.
Cheers
FD=CD/Cs *Fs
Cheers
OK, let's kick this off. Can you first get the frequency of the doppler shifted sound wave? I think your equation above (though you haven't defined what each variable represents) should tell you that.
Also, write out how to get your C's.
well i can find the wavelength of the car but i think its only when its stationary I am not sure
If Cs of the source is 30 m/s an the frequency is 600 hz
then the wavelength is
0.05 m
but I am not so sure where to go from there.. if i have Cs and Fs how do i find what the wavelength in front and behind is
actually i think i have the answer.. i used an equation that was stated in my textbook..
Wavelength behind = (vm+us)/Fs
where Vm= velocity of sound in medium
Us= velocity of source
and it gets an answer of 0.6 m
and
wavelength infront = (vm-us)/Fs
given an answer of 0.5 m
and from here i can calculate the frequency of each wavelength from V= F*(Lambda)
and
Awesome! Have a good one.
