Double Integral in Polar Coordinates
The discussion revolves around evaluating a double integral in polar coordinates to find the area in the first quadrant between two circles defined by the equations x² + y² = 256 and x² - 16x + y² = 0.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to determine the intervals of integration for the polar coordinates and expresses confusion about the correct setup for the integrals representing the areas between the circles.
  • Some participants question the intervals of integration and the reasoning behind choosing certain limits, particularly regarding the radius from the center of the circle to its edge.
  • Others suggest reconsidering the approach to integrating the second circle and clarify the use of the half-angle formula for integrating cos²θ.
The discussion is ongoing, with participants exploring different interpretations of the integration limits and the setup of the integrals. Some guidance has been offered regarding the use of the half-angle formula, but there is no explicit consensus on the correct approach yet.
Participants are working within the constraints of a homework assignment, which may limit the information available for resolving certain assumptions about the setup of the problem.
shards5
Using polar coordinates, evaluate the integral which gives the area which lies in the first quadrant between the circles x2 + y2 = 256 and x2 - 16x + y2 = 0.
Finding the intervals of integration for the polar coordinates.
From the first equation I get r2 = 256 therefore r = 16
From the second equation I get r2 - 16rcos[tex]\theta[/tex] therefore r = 16cos([tex]\theta[/tex])
Since it is the first quadrant theta will be from 0 to pi/2.
Now this is the part where I am confused about. My intuition is that I should integrate the bigger circle and then subtract the integral of the smaller circle within it so I would have something like the following.
[tex]\int^{\pi/2}_{0}\int^{16}_{0} r drd\theta - \int^{\pi/2}_{0}\int^{16cos\theta}_{8} r drd\theta[/tex].
Is this the right approach?
Sketch the region. The answer should be easy to check using the sketch.
The first integral looks fine. The second one doesn't.
I sketched it out and for the second one I am basing my intervals of integration of r from the center of the circle to the edge of the circle.That seems to make the most sense to me, however, a similar example in my book (which has a circle shifted 2 to the right instead of 8 and has a radius of 1 instead of 8) uses the radius from 0 to 2cos[tex]\theta[/tex] and that doesn't really make sense to me. If you could explain why the radius would be from 0 to 16cos[tex]\theta[/tex] in this case (or if it isn't) then that would be really helpful as I don't have that intuitive understanding yet.
Look at ordered pairs (r,θ). If r starts at 8, you will never cover the portion of the half circle that's less than 8 units from the origin.
That seems to make sense since if I think of [tex]\theta[/tex] as how much an imaginary line sweeps through and radius as how long that line actually is.
So now that I have the following:
[tex]\int^{\pi/2}_{0}\int^{16}_{0} r drd\theta - \int^{\pi/2}_{0}\int^{16cos\theta}_{0} r drd\theta[/tex]
After the first integration I get.
[tex]\int^{\pi/2}_{0} r^2/2 d\theta - \int^{\pi/2}_{0} r^2/2 drd\theta[/tex]
Plugging in I get
[tex]\int^{\pi/2}_{0} 128 d\theta - \int^{\pi/2}_{0} 128cos^2\theta drd\theta[/tex]
And now I am stuck because I don't exactly remember how to integrate cos2[tex]\theta[/tex]? How do you usually integrate something like cos2[tex]\theta[/tex] again?
By the half-angle formula,
[tex] \cos^2 \theta = \frac{1 + \cos(2\theta)}{2}[/tex]
which should make the integration easier.
Okay, then after integration I get the following.
128*pi/2 - [1/2[tex]\theta[/tex] + sin(2*[tex]\theta[/tex])/4]
Plugging in my values I get the following.
128*pi/2 - pi/4 - sin(pi)/4 + sin(0)/4
but this is wrong. I am not sure what I am doing wrong.
You forgot the factor of 128 on the second integral.
  • · Replies 19 ·
