Understanding Electric Field Lines: Curving and Splitting Nodes
The discussion focuses on drawing electric field lines for a homework problem involving curving and splitting nodes. Participants analyze a provided image, confirming that the electric field lines appear to curve left as nodes separate. Additionally, they note that in a T-shaped configuration, the lines curve towards the negative node on the right. The consensus is that the visual representation effectively captures the behavior of the electric fields in these scenarios. Overall, the participants agree on the interpretation of the electric field line behavior in the given configurations.
jcpwn2004
Hey I'm supposed to draw electric fields for this problem and I can't figure these 2 out.
There really isn't any.
It's included in the picture
http://img135.imageshack.us/my.php?image=physicsge1.jpg
Looks OK.
I've seen neater, but you seem to grasp the issues.
LowlyPion said:
Looks OK.
Ok so the main point of the one on the bottom is that the lines curve to the left as the nodes split away from each other?
And then for the T one they all just curve towards the negative node on the right?
That's the way I see it.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
