How Does Electric Field Influence Potential Difference and Particle Suspension?
  • Thread starter Thread starter pharaoh
A constant electric field of 750 N/C between parallel plates separated by 1.5 cm results in a potential difference of 11.25 V. When a person shuffles on a rug, a spark can jump if the electric field exceeds 4.0 x 10^6 V/m, leading to a potential difference of 6,000 V when standing 0.15 cm from another person. An oil drop with a charge of 8.0 x 10^-19 C suspended between plates with a potential difference of 1200 V and separated by 8.0 mm experiences an electric field of 150,000 V/m. The weight of the oil drop is calculated to be 1.2 x 10^-13 N. The calculations presented in the discussion are confirmed to be correct.
pharaoh
A constant electric field of 750 N/C is between a set of parallel plates. What is the potential difference between the parallel plates if they are 1.5 cm apart?
V=Ed
V= (750)(0.05)= 11.25 v
7. A spark will jump between two people if the electric field exceeds 4.0 x 10^ 6 V/m.
You shuffle across a rug and a spark jumps when you put your finger 0.15 cm from another person’s arm. Calculate the potential difference between your body and the other person’s arm.
V= ED
(4.0*10^6)(0.0015)= 6.0*10^3 V
8. An oil drop having a charge of 8.0 x 10^ –19 C is suspended between two charged parallel plates. The plates are separated by a distance of 8.0 mm, and there is a potential difference of 1200 V
between the plates. What is the weight of the suspended oil drop?
V= Ed
1200/0.008= E
E= 150000
is my answers right
E= mg\q
150000= mg\ 8.0*10^-19
mg= 1.2*10^-13 N
V=Ed
V= ED
V= Ed
1200/0.008= E
E= 150000
is my answers right
E= mg\q
mg= 1.2*10^-13 N
I still marvel at the ingenuity of the original experiment.
http://www68.pair.com/willisb/millikan/experiment.html
Seems like you are correct.
