Electric Circuit Help (Emf and Internal Resistance)
The discussion focuses on calculating the current and potential difference across resistors in a parallel circuit with resistances of 2.0 ohms, 10.0 ohms, and 20.0 ohms, powered by a 12.0 V EMF and no internal resistance. Participants emphasize using Ohm's Law, stating that the voltage across each resistor remains constant in parallel circuits. The total equivalent resistance (Req) can be calculated, but it's noted that finding Req is not necessary for determining the current through each resistor. The correct formulas for calculating individual currents are provided, highlighting the relationship between voltage, current, and resistance. Understanding EMF and internal resistance is also discussed as essential for solving the problem effectively.
IDreadPhysics
1. Find the current in, and the potential difference across, each resistor in the circuit shown below:
The circuit is a simple parallel circuit with 2.0 ohms at the first resistor, 10.0 ohms at the second, and 20.0 ohms at the third
The problem also gives you Emf which is 12.0 V and the internal resistance "r" which is 0 ohms
2. Voltage = Current*Resistance
Possibly: Voltage = Emf - Current*Resistance
Req (total resistance) = [(1/Resistance 1) + (1/Resistance 2) + (1/Resistance 3)]-1
3. I would attempt the problem but I've tried so many times and I'm just lost. I was absent the day this question was answered in class.
I thought you were supposed to find the Req first then use the voltage given to find the current in the system, but that's not helping me at all. I don't understand Emf or internal resistance so I'm not sure of its purpose.
I hope this helps. I'm on a laptop so I can't scan any images at all.
In parallel circuits the voltage through each branch is the same. Use Ohm's Law to find the current.
I don't believe that's correct.
\frac{1}{R_{eq}}=\frac{1}{R_1}+\frac{1}{R_2}+\frac{1}{R_2}
R_{eq}=\frac{R_1 R_2 R_3}{R_1 R_2 + R_1 R_3 + R_2 R_3}
This isn't really needed to find the current through each resistor.
Ohm's law, applied in this case:
V = I_1 R_1 = I_2 R_2 = I_3 R_3
Therefore...
I_1=\frac{V}{R_1}
I_2=\frac{V}{R_2}
I_3=\frac{V}{R_3}
You can use R_{eq} to see if you got it right...
V=I R_{eq}
I=\frac{V}{R_{eq}}=V\frac{R_1 R_2 + R_1 R_3 + R_2 R_3}{R_1 R_2 R_3}
and...
I = I_1 + I_2 + I_3
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
