Electric field at center of semi-circular bent rod of charge
The discussion focuses on calculating the electric field at the center of a semicircular rod of charge, specifically a uniformly charged insulating rod of length 14.0 cm with a total charge of 7.5 microC. The user correctly derives the expression for the electric field, E, as E = (2 * k_e * Q) / (L * r), but encounters confusion regarding the direction of the electric field and the value of r. The user mistakenly believes the resultant electric field should be positive, as the charge is positive, leading to a misunderstanding of the negative sign in their calculations.
  • Understanding of electric fields and Coulomb's law
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of charge density and its relation to total charge
  • Basic principles of electrostatics and vector components
  • Review the derivation of electric fields from continuous charge distributions
  • Study the concept of charge density and its applications in electrostatics
  • Learn about the significance of vector directions in electric field calculations
  • Explore the integral calculus involved in calculating electric fields from charge distributions
Students studying electrostatics, physics educators, and anyone interested in understanding electric fields generated by charged objects.
caesius
I have the correct answer just the wrong direction
A uniformly charged insulating rod of length 14.0cm is bent into the shape of a semicircle as shown in figure XXX. The rod has a total charge of 7.5 micro C. Find the magnitude and direction of the electric field at P, the center of the semicircle.
dE = k.dq.1/r^2
I set things up like this
http://img210.imageshack.us/img210/4690/physprobub2.png
Since the vertical components would cancel I just looked at the x components.
[tex] dE_{x} = \frac{k_{e}\cdot dq\cdot\sin\theta}{r^2} [/tex]
[tex] = \frac{k_{e}\cdot dx\cdot\lambda\cdot\sin\theta}{r^2} \ \ \mbox{as dq = dx\cdot\lambda}[/tex]
[tex] = \frac{k_{e}\cdot r\cdot d\theta\cdot\lambda\cdot\sin\theta}{r^2} \ \ \mbox{as dx = ds = r\cdot d\theta}[/tex]
[tex] = \frac{k_{e}\cdot d\theta\cdot\lambda\cdot\sin\theta}{r} \ \ \mbox{as dx = ds = r\cdot d\theta}[/tex]
So
[tex] E = \frac{k_{e}\cdot \lambda}{r} \int d\theta\cdot\sin\theta}[/tex]
(integral is from zero to pi)
[tex] E = \frac{k_{e}\cdot \lambda}{r} ( -1 - 1)[/tex]
[tex] E = \frac{-2\cdot k_{e}\cdot Q}{L\cdot r} \ \ \mbox{as \lambda = \frac{Q}{L}}[/tex]
When I substitute the values is I get the correct answer but it's negative. The bent rod is positive so the resultant electric field should be AWAY from the semicircle and therefor positve?!?
What have I done wrong?
The integral of sin from 0 to pi is 2. How did you get (-1-1)? BTW the antiderivative of sin(x) is -cos(x).
Sorry for reactivating this old thread, but I figured better that than starting a whole new thread.
I have gotten to the point of [tex] <br /> E = \frac{2\cdot k_{e}\cdot Q}{L\cdot r} \ <br /> [/tex]
but now my question is what is the r value? Of what my reasoning is telling me, it should be [tex] <br /> E = \frac{2\cdot k_{e}\cdot Q}{L^{2}} \ [/tex]
Is this right? Can anyone assist me?
  • · Replies 18 ·
