Electric field at the center of a semicircle
The discussion focuses on calculating the electric field at the center of a semicircle. Initially, the user attempted to derive the electric field using an incorrect integration range, leading to an incorrect result. Upon receiving feedback, they realized the need to integrate from 0 to π instead of π/2 to 3π/2, which is appropriate for a semicircle. After correcting the integration limits, the user found the correct electric field value to be approximately 4.9×10^5 N/C. This highlights the importance of proper integration limits in solving physics problems related to electric fields.
rocapp
See the image attached
Ex = (Kλ/R)*∫3/2ππ/2(cosθ)dθ
Ey cancels because there is an equal amount of force in both y directions. For the electric field on the x axis, the above equation can be used.
Given that λ=Q/L
λ=(85x10^-9 C)/(0.1 m)
=8.5x10^-7
R = L/θ
=(0.1 m)/(3/2π - π/2)
=0.03183
E = ((8.85x10^-9)(8.5x10^-7)/0.03183)*pi
= 7.424640507894822×10^-13
This is not correct. Please help! Thanks in advance.
Given that λ=Q/L
=8.5x10^-7
R = L/θ
=0.03183
take an element dx at θ with width dθ
then integrate from 0 to∏
Haha! I just realized my mistake as soon as you posted! Thank you very much!
To be clear for anyone who looks at this post for help in the future,
Since the integral from pi/2 to 3pi/2 is not going to have the correct coordinates to give you the correct length, you must integrate from 0 to pi since the shape is a semicircle (half a circle) or from 0 to pi on a trigonometric circle.
When you integrate from 0 to pi/2, the charge for half the semicircle is 240072.2588752749
Multiply that number by two, and the correct answer is:
4.9×105 N/CThanks again!
9K
