Electric field due to point charge
The discussion revolves around calculating the net electric field between two charged particles located on the x-axis. Particle 1 has a charge of -2.00x10^-7 C at x=6.0 cm, while particle 2 has a charge of +2.00x10^-7 C at x=21.0 cm. The net electric field at the midpoint is directed to the left, as both electric fields from the charges point in that direction. The participant confirms their understanding of the electric field direction and seeks clarification on the scenario if particle 1 were positive. The conclusion emphasizes that the net electric field would be zero only at the midpoint if both charges were equal and opposite.
th3plan
Two particles are fixed to an x axis: particle 1 charge -2.00x10^-7 at x=6.0cm and particle 2 at 2.00x10^-7 C at x=21.0cm. Midway between the particles, what is there net electric field?
E=kq/r^2
Ok so I drew the picture out, and i know q1 is negative so the electrive field is going towards it to the left, and q2 is + so that means the field is going to the left toward q1, so that means Enet= -E1-E2 , and its negative because there both going to the left? Am i correct on this ? I know the rest of problem is just plugging in numbers, but whant to make sure I am correct on theory. Also let's say that q1 was postive does that mean q1 would go to the left, and q2 field would go to the right, resulting in a zero net force ?
E=kq/r^2
I'd say you have grasped the concepts. The E field of 0 in your follow up is however only at the mid point which I'm sure you already understand.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
