Electric Field of a Straight Wire (now with the attachment)
The discussion focuses on solving a physics problem related to the electric field of a straight wire, with the user initially struggling to derive the correct expression. The user applies relevant equations and integration techniques to calculate the electric field, specifically addressing the components along the x-axis. After some confusion, it is revealed that the online homework program required the answer in terms of epsilon rather than a numerical value. Ultimately, the user resolves the issue independently. The thread highlights the importance of understanding the format required for homework submissions.
The Head
1. Homework Statement
The word document with the problem is attached below.
2. Homework Equations
dE=kdQ/r22
Ex=Ecos∅
3. The Attempt at a Solution
dE=kdQ/r2
E=kλ∫dy/(x2+y2) (integrating from y= -L/2 to L/2)
Ex=2kλ∫xdy/(x2+y2)3/2 (change integration to y= 0 to L/2, multiplying expression by 2)
Let y=xtan∅
dy=x(sec∅)2 d∅
=2kxλ∫x(sec∅)2/x3(sec∅)3 d∅
=2kλ/x∫cos∅ d∅
=2kλ/x(sin∅)
=2kλ/x(sin(arctan(y/x)) (evaluated from y=0 to y=L/2)
=2kλ/x(y/(x2+y2)1/2 (evaluated from 0->L/2)
=2kλ/x(L/2)(x2+(L2)/4)1/2
=((1.8X10^10)λL/(2x))*(1/x2+(L2)/4)1/2
This isn't the correct answer, though I don't know what actually is. I would appreciate any help or guidance!
Okay, I figured it out. I am using an online HW program and it just wanted the the answer in terms of epsilon, not a numerical value. Thanks anyway!
