Electric Field and Magnitude Problem
Two identical point charges, each +2.5 x 10^-6 C, are positioned near point P, which is 0.05 m from one charge and 0.12 m from the other, forming a right angle. To calculate the electric field at point P, the relevant formula E = k x Q / r^2 is applied for both charges. The electric field due to charge q1 is calculated as approximately 9 x 10^6 N/C, while the field from q2 is about 1.563 x 10^6 N/C. The next step involves decomposing these electric fields into horizontal and vertical components to find the resultant vector. The discussion emphasizes the importance of vector addition in determining the total electric field at point P.
pstir2
Two identical point charges, q1 = +2.5 x 10-6 C and q2 = +2.5 x 10-6 C, are placed as shown in the diagram below. Point P is a distance 0.05 m from q1 and 0.12 m from q2, such that the angle at P is 90 degrees. Calculate the magnitude of the Electric field E at point P.
Not sure which of these rules would apply. Also I suck at vectors
F = k x q1 x q2 / r^2
E = k x Q / r^2
So I have created the diagram and I believe I have to use the second formula twice, along with some trigonometry, but I'm not sure.
E1 = k x Q1 / r^2
E1 = k x +2.5 x 10^-6 / 0.05^2
E1 = 9 x 10^6
E2 = k x Q2 / r^2
E2 = k x +2.5 x 10^-6 / 0.12^2
E2 = 1.563 x 10^6
I Can't do vectors at all. Please help.
Step 1:
Decompose the E field you got at point P due to q1 to horizontal and vertical components.
Do the same for E field you got at point P due to q2.
That's exactly correct.
Keep going! Find the field from each charge, then find the resultant field by adding the vectors.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
