Electric field strength of a wire comparison
The discussion focuses on calculating the electric field strength at a distance from a charged wire, with an initial value of 2660 N/C at 7.79 cm. The user attempts to find the electric field strength at 12.7 cm using the formula E = (9*10^9) Q/ r^2 but ends up with an incorrect result of 1001 N/C. There is uncertainty about whether the correct formula is being used, with a suggestion to consider Gauss's Law for the calculation. The conversation highlights the importance of using the appropriate equations for electric fields around charged conductors. Understanding the correct application of Gauss's Law is crucial for solving such problems accurately.
pickleparty
1. Homework Statement
The electric field strength 7.79 cm from a very long charged wire is 2660 N/C. What is the electric field strength (in N/C) 12.7 cm from the wire?
2. Homework Equations
E= (9*10^9) Q/ r^2
3. The Attempt at a Solution
i have energy. so is tried to solve backwards for the first one for Q. Then i plugged in the new Q with relation to 0.127 m. I got 1001 N/C which is wrong. Am I even using the right formula?
Do you know Gauss's Law?
ya is that what i needed to use?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
