Electric Forces with particles and Columbs law problem.
The discussion revolves around calculating electric forces using Coulomb's law for two charged particles. The first part of the problem, involving charges of -7.13 × 10^-6 C and 1.87 × 10^-6 C separated by 0.0284 meters, yields a force of 148.7 N. For the second part, the challenge is to determine the charge q3 of two identical positive particles that exert the same force when separated by the same distance. Despite attempts to solve for q3 using the formula Fe = kq3^2/r^2, the calculated value of 3.6 x 10^-6 C is deemed incorrect. The issue may relate to significant figures or calculation errors, as participants suggest verifying the precision of the answer.
Toon
Two particles, one with charge -7.13 × 10-6 C and one with charge 1.87 × 10-6 C, are 0.0284 meters apart. What is the magnitude of the force that one particle exerts on the other?
Two new particles, which have identical positive charge q3, are placed the same 0.0284 meters apart, and the force between them is measured to be the same as that between the original particles. What is q3?
Fe=Kq1*q2 /r^2
So for the first part. I got the answer right for the force which was 148.7 N. However for the second part, I tried doing Fe= kq3^2/r^2 and solved for q3. However I keep getting 3.6 x 10 ^-6 columbs and that's wrong according the my physics homework website. Any help where I am going wrong?THanks!
Could it be that you are not expressing your answer to the correct number of significant figures?
thats what I am thinking. However I've tried diffrent ways of expressing the answer and its still wrong so I am assuming my numbers might be off.
What do you get to 3 significant figures?
3.651 x 10 ^-6 but the answer is still wrong
Well, your answer certainly looks correct to me.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
