Electricity-Resistance Question
  • Thread starter Thread starter Bullkank
The discussion centers on calculating the required value of a second resistor to achieve a specific voltage drop across a combination of resistors in parallel. The student needs a voltage drop of 5.0V with a total current of 2.0mA. The solution reveals that the second resistor should be 6.7 kOhms, resulting in an effective resistance of 2.5 kOhms for the combination. The calculations utilize Ohm's Law and the formula for equivalent resistance in parallel circuits.
  • Understanding of Ohm's Law (V = I * R)
  • Knowledge of parallel resistor combinations
  • Familiarity with calculating equivalent resistance
  • Basic circuit analysis skills
  • Study the principles of parallel and series resistor combinations
  • Learn how to apply Ohm's Law in various circuit configurations
  • Explore practical applications of voltage dividers in circuits
  • Investigate the impact of resistor tolerances on circuit performance
Students in electrical engineering, hobbyists constructing circuits, and anyone looking to deepen their understanding of resistor combinations and circuit analysis.
Bullkank
A Student needs to construct a circuit in which there is a voltage drop of 5.0v across a resistance combination, and a total current of 2.0mA flowing through the combination. She has a 4000 Ohm ( 4.0kOhm) resistor which she wants to use and proposes to add another resistor in parallel with it.
a) What value should she use for the second resistor
b) Determine the effective resistance of the combination
I have no idea how to work this out. The answers are
a) 6.7 kOhms
b) 2.5 kOhms
I just need to know how to get to that answer
Voltage drop across the "equivalent" resistance, meaning the resistance shown by the 2 resistances in parallel, equals 5V.
V = I*R => R = V/I
R = 5V/2mA = 2,500 OhmsNow this R is the equivalent resistance R_eq, which can be found by:
1/R_eq = 1/R1 + 1/R2
or after rearranging: R_eq = R1*R2/(R1+R2) , where you know one of the resistors (R1 = 4 kOhm).
  • · Replies 17 ·
13K
