Electronic Steam Tables Programs
Users are seeking recommendations for electronic steam table software that is simple and compatible with Excel, specifically for calculating steam properties like enthalpy, saturation temperature, density, and pressure. One user mentioned finding a resource at steamtablesonline.com and inquired about others' experiences with it. Another user recommended 'coolprop', an Excel add-in that works well but has limitations, particularly with mixtures, suggesting it is suitable for water-related calculations. The discussion highlights the need for effective tools in thermodynamic property calculations. Overall, users are looking for reliable software options to enhance their steam property analysis.
naggy
Hi all,
Been a while since I posted in these forums. Looking for advice on steam table software package.
I am looking for a relatively simple software package to look up steam properties. Preferably compatible with Excel. It at least has to be able to compute
  • SH steam enthalpy as a function of steam temperature and pressure
  • Saturation temperature as a function of pressure
  • Density of SH steam as a function of steam temperature and pressure
  • Saturation pressure as a function of temperature
During my online search, I found this
http://www.steamtablesonline.com/
Does anyone have experience with this software package? What are you using for steam tables and thermodynamics properties of materials.
I use 'coolprop', an excel addin, simple and works well.
Looks like the excel add-in only includes a limited amount of the function library. Or am I missing something? Do I need anything except for the excel add-in files?
iirc the limitations are mainly that the add in can't do mixtures. If you are only interested in water it should be fine.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
