Electrostatic Force of Water on a Chlorine Ion
The discussion focuses on calculating the electrostatic force exerted by a water molecule on a chlorine ion. The dipole moment of water is given, and the electric fields generated by both the water molecule and the chlorine ion are calculated separately. The user attempts to find the net electric field and subsequently the force on the chlorine ion by multiplying the net electric field by the charge of the ion. Clarification is sought regarding the multiplication of the net electric field by the charge of the chlorine ion to determine the force. The conversation emphasizes understanding the relationship between electric fields and forces in electrostatics.
moonlight13
The dipole moment of the water molecule ({\rm H}_{2}{\rm O}) is 6.17 \times 10^{-30}\;{\rm C \cdot m}. Consider a water molecule located at the origin whose dipole moment p_vec points in the positive x direction. A chlorine ion ({\rm Cl}^{-}), of charge -1.60 \times 10^{-19}\;{\rm C}, is located at x=3.00 \times 10^{-9} meters. Assume that this x value is much larger than the separation d between the charges in the dipole, so that the approximate expression for the electric field along the dipole axis can be used.
Find the magnitude of the electric force, ignoring the sign, that the water molecule exerts on the chlorine ion.
attempt to question:
the water has an electric field to the right and the chlorine ion has it to the left ..
i calculated the E for water and Cl- seperately
E (H2O):
E = 2Kp/r^3 = 2*(9x10^9)*(6.17x10^-30)/(3.00x10^-9)^3 = 4.11 x 10^6 N/C
E (Cl-):
E = KQ/r^2 = K(1.60x10^-19)/(3.00x10^-9)^2 = 1.6 x 10^8 N/C
now to find the force do I find the E(net) = 1.6 x 10^8 - 4.11 x 10^6 = 1.56 x 10^8 N/C
then times by charge? .. so E(net) x (1.6 x 10^-19) ..? = 2.49 x 10^-11 N...
Am I doing it right..??
Thank
Can OSmeone please help me with this question..
Thank you
Why did you multiply it by 1.6x10^-19?
multiply which part by that??
why did you multiply E_net by 1.6x10^-19?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
