MalachiK
- 137
- 4
I'm trying to show that not all (half) of the energy supplied by the power supply ends up in the capacitor when the capacitor is charged through a resistor. I've looked at some of the other threads on these sorts of topics and I'd thought I'd have a go at working through it myself. The treatments of this problem that I've seen seem to consider the work done moving each charge element through a potnetial differnece but I thought I could do this another way. Anyway, it's not going well and I'd appreciate any advice.
I've included these in the working below...
It seems to me that you can start by considering the power transferred to C and to R over a given time interval and then integrate to get the energy transferred in this time.
At first, all of the p.d. is dropped across R. Let's call this V0. We can also call the initial current I0. None of the p.d. is dropped across the cap at first.
After time t, the p.d. across R is V0e-t/RC and the p.d. across the cap is V0(1-e-t/RC). The current is I0e-t/RC.
At ant time t, the power delivered to the resistor is V(t)I(t). So after some time T, the energy lost as heat in the resistor should be V0I0\int^T_0e-2t/RC dt
Setting Vo Io as Po and with some calculating I get...
ER=(2Po/RC)(1 - e-2T/RC)
It also occurred to me that the total energy delivered to the circuit would be \int^T_0Vo Io e-t/RC dt [the total p.d. across the circuit doesn't change, only the way it is shared out changes. The current falls with time.]Evaluating this gives me
ET = (Po/RC)(1 - e-T/RC)So far so good (unless I've made some stupid mistake!) Now for the energy to the capacitor. Following the same reasoning as before I get that...
EC= Po \int^T_0 e-t/RC - e-2t/RC dt
EC = (Po/RC)(2e-2T/RC -e-T/RC - 1)Now I'm doubtful of this result because it looks like it's got too many terms in it, but on the other hand, when I calculate EC = ET - ER I get the same result so at least if I'm wrong I'm internally consistent!
At this point my algebra fails me and I can't see how I can compare my expressions for each of the energies to show something like EC = 0.5 ET. Is this because there's something seriously wrong with my thinking?
