Is Dropping a Metal Block into a Lake a Reversible Process in Thermodynamics?
The discussion centers on the thermodynamic process of a metal block reaching thermal equilibrium with a lake, raising questions about its reversibility and entropy. While the process itself is not reversible, a reversible path can be conceptualized by using a series of temperature reservoirs to gradually cool the block. The integral provided calculates the change in entropy per unit mass, necessitating multiplication by the block's mass for the total entropy change. The importance of understanding the distinction between actual and reversible processes in thermodynamics is emphasized. Overall, this highlights key concepts in entropy calculations and reversible processes in thermodynamics.
Sum Guy
Hello all.
I have a quick question about entropy... I've just been formally introduced to it.
Consider the example of a metal block of mass m and heat capacity Cp at temperature T1 = 60C being dropped into a large lake of temperature T2 = 10C.
$$\Delta S_{block} = \int\frac{dQ_{reversible}}{T} = \int_{T_1}^{T_2}\frac{C_pdT}{T}$$
I have a few questions... how would the block reaching thermal equilibrium with the lake be classed as a reversible process (it must be otherwise we wouldn't have the above calculation)? Why can we ignore the blocks mass? Are there any general tips you could provide that might help me tackle questions on entropy?
Many thanks.
Science news on Phys.org
Sum Guy said:
Hello all.
Many thanks.
You are correct in recognizing that the process you described is not a reversible process. But, to calculate the change in entropy of the block for this change, you need to devise a reversible path from the initial state to the final state, and calculate the integral of dQ/T for that path. One such path is where you contact the block with a sequence of reservoirs having gradually lower temperatures (so that its temperature only differs only slightly from that of the reservoir it is currently in contact with). That leads to the integral you wrote down. Of course, that integral only gives the entropy change per unit mass. To get the actual entropy change of the block, you need to multiply by the mass of the block.
Likes Sum Guy
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
