Equivalent Impedance Calculation for Circuit - Help Needed
To calculate the equivalent impedance of the given circuit, first determine the impedance of the resistor and inductor in series, represented as Z_RL. Next, calculate the impedance of the capacitor in parallel, denoted as Z_C. The total impedance can be found using the formula 1/Z_total = 1/Z_RL + 1/Z_C, taking into account the phase differences of the impedances. The series impedance of the resistor and inductor is Z_R + jωL, while the capacitor's impedance is -j/(ωC). The final equivalent impedance combines these elements accordingly.
thenewbosco
see diagram http://img.photobucket.com/albums/v11/biggm/z.jpg
The question is to find the equivalent impedance for the circuit.
I am not sure how to solve this, it is simple in the case of all three elements in series but with the capacitor in parallel i am not sure how to solve it.
thanks for the help
thanks for the help
Find the impedance of the inductor and resistor in series. Then find the impedance (pure reactance) of the capacitor in parallel. Then add the impedances using:
\frac{1}{Z_{total}} = \frac{1}{Z_1} + \frac{1}{Z_2}
It gets a little difficult because the impedances have phase differences.
\frac{1}{Z_{total}} = \frac{1}{\sqrt{R^2 + \omega^2 L^2}} + \omega C
AM
An equivalent alternative is to say,
Z_r = R
Z_c = - \frac{j}{ \omega C} = \frac{1}{j \omega C } = \frac {1}{\omega C } \angle {-90^o}
Z_L = j \omega L = \omega L \angle {90^o}
Then treat the R-L in series, and call it Z_{RL} [/tex]<br /> <br /> and make that in parallel with Z_c, <br /> <br /> which gives you: Z_{eq} = (Z_c \backslash \backslash (Z_r + Z_L) )
