Evaluating Integrals using the Residue THM
  • Thread starter Thread starter brianhawaiian
    Integrals Residue
The discussion revolves around evaluating the integral of the function sin(z)/z² over the contour where |z|=1, utilizing the Residue Theorem. Participants are exploring the nature of the poles of the function involved.
  • Participants are questioning which residue rule to apply based on the type of pole present in the function sin(z)/z². There is uncertainty about whether to integrate first or determine the residue directly.
Some participants have identified potential poles of the function and are discussing their nature. There is a mix of opinions regarding the classification of the pole at z=0, with some suggesting it may be a simple pole while others consider it a double pole. The conversation is ongoing with no clear consensus reached.
Participants are navigating the definitions and implications of different types of poles as they relate to the application of the Residue Theorem. There is a noted confusion regarding the correct approach to take in the evaluation process.
brianhawaiian
integral |z|=1 of sinz/z2dz
Rule #1 if f(z) has a simple pole at z0, then
Res[f(z),z0] = lim(as z goes to z0) (z - z0)*f(z)
Rule #2 if f(z) has a double pole at z0, then
Res[f(z),z0] = lim(as z goes to z0)d/dz (z - z0)2*f(z)
Rule #3 If f(z) and g(z) are analytic at z0, and if g(z) has a simple zero at z0 then,
Res[f(z)/g(z), z0] = f(z0)/g'(z0)
Rule #4 If g(z) is analytic and has a simple zero at z0 then,
Res[1/g(z), z0] = 1/g'(z0)
Just confused on which one to use? Would I integrate first? And if so what would my z0 be in Rest[..., z0]
Thanks
What kind of of pole does the function sinz/z2 have and where is it? Although I think 1 and 2 will give the same result.
double pole at i/2 and -i/2?
Edit: Actually simple pole at z = 0?
Yep.
