Expanding (cosx)^-1/2: Simplifying with Binomial Expansion
In summary, In order to find the first few terms of the binomial expansion of (cosx)^-1/2, you need to differentiate (cosx)^-1/2 a few times, then take the binomial expansion of that.
Poop-Loops
732
I have the series (cosx)^-1/2 (so it's square-rooted and on the bottom)
And I need to get the first few terms. My idea has been to do this: [1 + (cosx - 1)]^-1/2
But I have no idea how to take the binomial expansion of that. Do I:
Take the BE first, substituting "cosx - 1" as just X or something, then after I get the first few terms of that, substitute in the series for "cosx - 1" back into X and adding everything up? The only reason I haven't tried this yet is because it seems like this would take an infinite amount of work...
if you only need the first few terms, why no just differentiate (cosx)^-1/2 a few times?
[tex]\frac{1}{\sqrt{\cos x}} = 1+ \frac{1}{2}\left[ \frac{d}{dx}\frac{1}{\sqrt{\cos x}}\right]_{x=0}x+...[/tex]
Because your 1st derivative is missing a sinx (Unless I don't get your mathematical notation...), and the next derivatives only get more gruesome. This teacher keeps spouting "we're smart, but lazy", so I'm guessing there is a trick I am missing here.
it's not messy at all after you evaluate the derivative at x=0. All the cos become 1 and all the sines become 0.
quasar, you are doing a MacLaurin series right?
Are you going to say that after a few derivatives, nasty sines come poping in the denominator?
Just to be on the same side, make that a Taylor series centered on [itex]\pi/4[/itex] where both cos and sine are [itex]1/\sqrt{2}[/itex].
Errr... when can I evaluate at x=0? Don't I need to keep it a variable until I am completely done deriving?
Yes. It's true you are lazy, lol.
I tried this once already. I got to through 2 derivations before it became really ugly. And my f(0)'s were something like 1, 0, and 1/2. That only makes it 2 terms, really, unless I want to cheat and say it's 0x. But I probably can't. So if all the odd n terms are supposed to be 0, I have a lot of deriving to go. I said I'm lazy, but smart. Smart enough to know that there has to be a different approach. This isn't a calc class where we are learning this the first time and have to go through this just to know how it's done. This is math physics, so it's mainly just a review + more critical thinking.
Alright, so let's get back to your first idea.
[tex](\cos x)^{-1/2} = (1+(\cos x - 1))^{-1/2} \equiv (1-X)^{-1/2}[/tex]
Expand this in a binomial series, then resubstitute X--> cos(x)-1. You will have what you want: a series expansion for (cosx)^-1/2. It is not a power series, but it is a series expansion.
It is frequent that calc classes do not cover the binomial series for non-positive integer exponents, but any physics class will assume that you know it. See
http://en.wikipedia.org/wiki/Binomial_series
The series you find will converge for all values of x such that |X(x)|<1. Find what that corresponds to in terms of x.
I have to get a power series expansion (or whatever it's called, where it's 1 + x/2! etc). So would I then expand cosx - 1 and plug those results into each individual binomial expansion? That sounds like just as much work. But I guess I have to try something.
yeah, do that then. Since X = cos(x) - 1, and cos(x)'s power series's first term is 1, the 1's cancel and then the term of lowest degree in [itex]X^n[/itex] is [itex]x^n[/itex]. So if you decide to keep only the terms up to degree 2, you're left with the first two terms (in x) of X and the first term (in x) of X².
Related to Expanding (cosx)^-1/2: Simplifying with Binomial Expansion
What is (cosx)^-1/2?
(cosx)^-1/2 is an expression that represents the inverse square root of the cosine of x. It is often used in trigonometric functions and can also be written as 1/√cos(x).
How do you expand (cosx)^-1/2?
(cosx)^-1/2 can be expanded using the binomial expansion formula: (1 + x)^n = 1 + nx + (n(n-1)/2!)x^2 + ... + (n(n-1)(n-2)...1/3!)x^3 + ...
Why is binomial expansion used to simplify (cosx)^-1/2?
Binomial expansion is used because it allows us to expand a binomial expression with a fractional or negative exponent into a series of terms that can be simplified.
What is the general formula for expanding (cosx)^-1/2 using binomial expansion?
The general formula for expanding (cosx)^-1/2 is: (cosx)^-1/2 = 1 - (1/2)x^2 + (3/8)x^4 - (5/16)x^6 + ... + (-1)^(n+1)(2n-1)/2^n x^(2n) + ...
Are there any restrictions for expanding (cosx)^-1/2 using binomial expansion?
Yes, for the binomial expansion to be valid, the value of x must be within the convergence interval of the expansion, which is typically between -1 and 1. Additionally, the exponent in the expression must be a non-negative integer.
