Find Ice Melted & Final Temp w/ 10g Steam & 50g Ice
  • Thread starter Thread starter Jennifer001
    Final Ice Steam
The problem involves the thermal interaction between steam at 100°C and ice at 0°C, specifically calculating the amount of ice melted and the final temperature when 10g of steam is added to 50g of ice.
  • Participants discuss the conservation of energy principle and how to set up the equations for heat transfer between the steam and ice. There are attempts to clarify the roles of latent heat and specific heat in the calculations. Questions arise regarding the correct formulation of temperature changes and the interpretation of the final temperature.
The discussion is ongoing, with participants offering insights into the necessary equations and concepts. Some guidance has been provided regarding the need to consider latent heats and the proper setup of temperature changes, but there is no explicit consensus on the correct approach or final temperature.
Participants express uncertainty about the calculations and the implications of their results, particularly regarding the final temperature being negative. There is also mention of specific heat values and latent heats that may be relevant to the problem.
Jennifer001
steam at 100C is added to ice at 0C find the amount of ice melted and the final temperature when the mass of steam is 10g and the mass of ice is 50g
Q=mcdT
Q=ML
Qmelt=MiciT+MiLf
=0.05(2090)(100C)+(0.05)(3.33x10^5)
=27100J
27100+Micw(Tf-0C)+Mscw(Tf-20C)=0
Tf=[100(0.01)(4190)-27100]/[(0.05)(4190)+(0.01)(4190)]
=-91
am i doing this question correctly? cause in the question it askes for the final temperature but i don't think the finall temperture would be -91 when it starts out with 100C and 0C.. also I am not sure how to find the amount of ice melted can someone help?
i thnk it has something to do with finding out the final temperture then plug it into Q=mcdT and you solve for m?? is this correct?.. but i still don't know how to find the final temperture correctly.. please help
Since energy is conserved you have:
Energy lost by steam changing to water + Energy lost by that water cooling to T = Energy needed to melt ice + energy needed to heat that water to T
so is the equation:
MscwdT+MwcwdT=MicidT+MwcwdT
Ms= mass of steam
Mw= mass of water
Mi= mass of ice..
sorry I'm really lost in thermodynamics
Not quite.
The heat of melting/boiling doesn't have a temperature - there is no T change.
When the steam condenses it is cooling from 100deg, this water loses energy so it's temperature change is (100-T)
You will also need these values (or whatever is given in the question)
Specific heat water, c = 4.184 J/g.K
Heat vapourisation = 2260 J/g
Heat fusion = 333.5 J/g
I'm pretty sure you're going to need to incorporate the latent heats of fusion in there.
and mgb_phys, are you sure it's (100-T) Shouldn't the change in temperature always be Tf-Ti?
unless you're going to throw the magnitude brackets around it?
T is the final temperature, the question needs \deltaT, which for the steam is (100-
T) and for the ice (0+T).
10K
  • · Replies 18 ·
16K
