Find the acceleration of the smaller mass. Pulley physics
The discussion revolves around calculating the acceleration of a 2kg mass connected to a 3kg mass over a frictionless pulley. The net force acting on the system is derived from the difference in gravitational forces on the two masses, leading to the equation Fnet = T - mg. After establishing the equations for both masses, the acceleration is found to be 1.96 m/s², with tension calculated at 23.52 N. Participants emphasize the importance of drawing free body diagrams for clarity and understanding the role of tension as the force exerted by the string on each mass. The conversation highlights the relationship between tension, gravitational forces, and the resulting acceleration in a pulley system.
kashiark
A 2kg mass and a 3kg mass are attached to a lightweight cord that passes over a frictionless pulley. The hanging masses are free to move. Choose coordinate systems for the two masses with the positive direction up for the lighter weight and down for the heavier weight.
F=ma
Fnet = Ft-Fg = 3g-2g = g the tension force on the smaller mass is equivalent to the weight of the heavier mass, so the net force acting on the object is g
(m1+m2)a=g
a=1.96 m/s² I know this is the answer, but I'm not sure why. If we already know that the force on the object is g, why don't we just say g=2a and get a=4.9 m/s²?
We don't know that the force on the object is g, in fact g is an acceleration not a force. There is tension T that acts on each mass as well. Draw a complete free body diagram for each mass, then write Newton's Second Law in each case. This should give you two relations linking the masses, the acceleration and the tension.
The force would be 9.8 Newtons. 3kg*9.8m/s²-2kg*9.8m/s² = 9.8 Newtons. The tension force would just be the gravity of the other mass since it's frictionless, and it's a pulley wouldn't it?
The tension acting on each mass is the same, I agree. However, if the tension on the other mass is the same as the weight but in the opposite direction, then the net force on the mass will be zero and the mass will not accelerate, don't you think? Like I said, draw a free body diagram for each mass.
The tension acting on each force would be the weight of the other mass, so the net force acting on each mass would be the same, 9.8 Newtons right? I drew a free body diagram for each mass. On the smaller weight, tension is greater than gravity for the, and on the greater weight, gravity is greater than the tension force.
Let's consider the smaller weight for the time being. You say that tension is greater than gravity and that is absolutely correct. So if you wanted to write an expression for the sum of all the forces (=net force) on that mass, how would you write this sum? (fill in the blank)
Fnet on smaller mass = ___________ ?
The weight of the bigger mass - the weight of the smaller mass = Net force. The only upward pull (which I'm using as tension here) on the smaller mass is the weight of the larger mass and vice versa. 3*9.8-2*9.8 = 9.8 Newtons.
So you are saying that the net force on the 2 kg mass is 9.8 N up and the tension on the 3 kg mass is 9.8 N down. Hmm... let's see what that implies. The net force is mass times acceleration so acceleration is net force divided by mass. According to you then
Acceleration of 2 kg mass = 9.8/2 = 4.9 m/s2
Acceleration of 3 kg mass = 9.8/3 = 3.3 m/s2
The acceleration cannot be different otherwise the rope connecting the two mass will stretch, which is not the case here. So what do you think? Will you draw free body diagrams for each mass separately or will you not? You might wish to check out this reference
http://en.wikipedia.org/wiki/Atwood_machine
If we just look at the thing as a whole, this makes sense: the net force on the entire system is 9.8 Newtons, and the acceleration for both of them is the same in the same direction: clockwise. I thought that a free body diagram was for the entire system; how can I draw it for just one? Am I wrong that the tension force for one mass would just be the weight of the other?
The net force on a mass hanging from a string m is always
Fnet = T - mg
If the mass accelerates up, then from Newton's Second Law
Fnet = T - mg = +ma (T > mg).
If the mass accelerates down,
Fnet = T - mg = - ma (T < mg).
If the mass moves with constant velocity or is at rest,
Fnet = T - mg = 0 (T = mg).
You need to write such equations for each of the hanging masses separately and you will end up with two equations and two unknowns, the acceleration a and the tension T.
Small:
Fnet = T-mg = ma
Fnet = T-19.6 = 2a
T - 19.6 = 2a
Big:
Fnet = T-mg = -ma
Fnet = T- 29.4 = -3a
T - 29.4 = -3a
A few questions: since it's a frictionless pulley, wouldn't the tension force be equivalent to the weight of the other? In the last equation, shouldn't the ma be positive because "Choose coordinate systems for the two masses with the positive direction up for the lighter weight and down for the heavier weight"? I can't solve it like a system of equations because the tension forces are different right?
This is an ideal pulley. Ideal pulleys change the direction of the tension but do not affect its magnitude. So the symbol "T" in the above equations stands for the same number. Go ahead and solve the system.
** Edit **
If you take "down" to be positive for the heavier mass, then on the other side of the second equation you need to make the sign of the tension negative (because is is up) and the sign of the weight positive (because it is down). Essentially, this amounts to multiplying both sides of the second equation that you have by -1. It does not change anything.
29.4-T=3a
T-19.6=2a
T=29.4-3a
29.4-3a-19.6=2a
9.8=5a
a=1.96 m/s²
T-19.6=2(1.96)
T=23.52N
So the answer is 1.96 m/s²
Thanks very much! However, I still have a problem: what exactly is tension? I was defining it as the entire upward force on the mass which is obviously incorrect.
Very good. Here, tension is the force exerted by the string on each mass. You can view it as the "entire upward force" but don't confuse it with the "Normal force" which is also an upward force. Tension is exerted by a string on a mass and points away from the mass along the string. Normal force is exerted by a surface on a mass and points away from the surface. You can't have tension without a string or normal force without a surface.
I am curious, why do you say that your way of looking at tension is obviously incorrect?
I solved for T = 23.52N, but it was for both masses. I thought that it was the upward force due to the mass of the other weight. For instance, I thought that for the smaller mass, the tension would be the weight of the bigger mass and vice versa.
I think you have sorted things out now. You may to practice some tension problems or read solve examples in your textbook involving tension.
Just making sure: I was wrong?
The tension is 23.5 N acting "up" on both masses.
So the force is just from whatever the pulley is attached to?
No. The forces acting on each mass are from whatever is touching or interacting with each mass. Here you have the rope and the invisible force of gravity acting on each mass. The rope force is the same for both masses.
I meant the tension force is just from whatever the pulley is attached to.
Yes, the pulley experiences two forces T + T down and its support provides force 2T up so the net force on it is zero.
