Finding b in Van der Waals Equation?
The discussion revolves around the Van der Waals equation, specifically in the context of an isobaric process involving an unidentified gas. Participants are trying to determine the value of the parameter 'b' in the equation p(V-b)=nRT, which is essential for calculating initial and final temperatures during a volume change from 1m³ to 2m³ with 1 mole of gas.
  • Participants discuss the definition of 'b' and its dependence on the type of gas, with some suggesting it represents the excluded volume. Others express confusion about how to find 'b' without knowing the specific gas properties. There are also inquiries about the implications of using the Van der Waals equation for calculating changes in internal energy and temperature.
The conversation is ongoing, with various interpretations of the role of 'b' in the calculations being explored. Some participants have provided algebraic expressions for initial and final temperatures, noting that 'b' cancels out in the temperature change equation, suggesting a productive direction in the discussion.
Participants mention constraints related to the lack of specific gas information and the implications of using the Van der Waals equation versus ideal gas assumptions. There is also a reference to the relationship between heat capacities and their relevance to the problem at hand.
DaynaClarke
Member has been warned not to remove the template.
I've got a question that requires me to use the Van der Waals equation in the form:
p(V-b)=nRT
The process is isobaric, the volume changes from 1m3 to 2m3, and there is 1 mole of the unidentified gas.
Ultimately, I need to find initial and final values of T. So I rearranged the formula:
p(V-b)/nR=T
So I need b. I think b is the volume per mole, so that's how I worked it out - as V/n. However, this gave me b as 1m3/mol and 2m3/mol. That gives me initial and final temperatures of 0K, which I'm guessing is wrong.
In short, if someone could point me in the right direction as to what b actually is, I would very much appreciate it. Thank you.
p(V-b)=nRT
p(V-b)/nR=T
What is the exact statement of the problem?
##b## should be the excluded volume for two particles of the gas (https://en.wikipedia.org/wiki/Van_der_Waals_equation) so it depends on the kind of gas you are working with. And it makes sense because because VdW introduced his formula to take in account for different kind of molecules (Pv=RT handles all gases the same way).
If you don't know anything about the gas I don't know how you can find a correct value for ##b##
"The equation of state of n moles of a gas is p(V-b)=nRT. The molar heat capacities of the gas at constant pressure and constant volume, cp and cv, satisfy cp - cv = R, where R is the gas constant, and γ = cp/cv = 5/3.
Find the change in internal energy of one mole of the gas in an isobaric expansion at a pressure of 1 bar from a volume of 1 m3 to 2 m3."
I have values for cp and cv, and I know that ΔU= Q - W = n⋅cp⋅dT - pdV. However, due to being unable to identify values for b at initial and final volumes, I don't know how to find initial and final temperatures.
This equation is incorrect. For this equation of state, $$\Delta U=nC_v(T_2-T_1)$$
Do you know how to show that this in the change in internal energy for this equation of state?
Algebraically, in terms of p, ##V_1## and b, what is the initial temperature?
Algebraically, in terms of p, ##V_2##, and b, what is the final temperature?
From these algebraic expressions, what is ##(T_2-T_1)##? Does it involve b?
If you have experimental data, you could do a best fit to your data to find b.
That's not necessary. To solve this problem, the value of b is not needed.
Is it because the gas is ideal, and the internal energy of an ideal gas is purely kinetic, so it only considers the heat? I'll admit I'm not sure why it's Cv and not Cp because volume isn't constant, but pressure is.
$$\frac{p(V_1-b)}{nR} = T_1$$
$$\frac{p(V_2-b)}{nR} = T_2$$
$$T_2-T_1 = \frac{p(V_1-V_2)}{nR}$$
So it doesn't contain b at all, it cancels out.
No. This gas is not ideal. Are you familiar with the following equation for a general non-ideal gas:
$$dU=nC_vdT-\left[p-T\left(\frac{\partial p}{\partial T}\right)_V\right]dV$$
If not, then your teacher did you a disservice by assigning you this problem. In any event, for the particular equation of state in the present problem, what do you get for the term in brackets?
Regarding Cv and Cp, you are aware of the following definitions, correct?:
$$nC_v=\left(\frac{\partial U}{\partial T}\right)_V$$and $$nC_p=\left(\frac{\partial H}{\partial T}\right)_p$$So, Cp is always associated with H and Cv is always associated with U. And, for this gas, if you did the math above correctly, you know that U is independent of V, and depends only on T.
These results are correct. So, what do you get if you substitute this result for the temperature change into the equation for ##\Delta U##?
DaynaClarke said:
Is it because the gas is ideal, and the internal energy of an ideal gas is purely kinetic, so it only considers the heat? I'll admit I'm not sure why it's Cv and not Cp because volume isn't constant, but pressure is.$$\frac{p(V_1-b)}{nR} = T_1$$
Great job. One thing I often tell students is that if you are not given a value that appears in an equation, and you are not asked for it, and you don't have the information needed to find it, it probably cancels out.
  • · Replies 31 ·
22K
10K
