Finding Electric Field of Two Charges
The problem involves calculating the electric field created by two point charges: a charge Q=1 μC at x=0 and a charge -Q/2 at x=4 m. The objective is to determine the position along the x-axis where the electric field is zero.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the setup of the electric field equations and the conditions under which the fields from both charges can be equal. There is an exploration of the algebraic manipulation involved in isolating the variable r.
Some participants have attempted to solve the equations but express uncertainty about their algebraic steps. Guidance has been offered regarding the manipulation of equations and the conditions for taking reciprocals. Multiple interpretations of the algebraic steps are being explored.
Participants are working under the constraint of not approximating decimal digits in their final answer. There is also a discussion about the implications of the negative charge on the electric field direction.
erok81
There is a charge Q=1 μC located at x=0 and a charge -Q/2 located at x=4 m. What is the E-field.
At what value of x is the E-field zero? Express your answer in meters and do not approximate decimals digits.
E=\frac{q_1 q_2 k_c}{r^2}
Removing the test charge:
\frac{E}{q}=\frac{q_n k_c}{r^2}
I have this solved, but I am going wrong somewhere and can't see my mistake. Here is my work and the correct final answer.
To find the E field at x=100, E1-E2=0. E2 is being subtracted due to q2 being negative.
This gives E1=E2
\frac{q_1 k_c}{r^2}=\frac{q_2 k_c}{(r-4^2)}
\frac{(r-4)^2}{r^2}=\frac{q_2 k_c}{q_1 k_c}
\left(\frac{(r-4)}{r}\right)^2=\frac{q_2 k_c}{q_1 k_c}
\frac{r-4}{r}= \pm \sqrt{\frac{q_2}{q_1}}
1-\frac{4}{r}= \pm \sqrt{\frac{q_2}{q_1}}
-1\left(-\frac{4}{r}= \pm \sqrt{\frac{q_2}{q_1}} -1\right)
\frac{4}{r}= \pm \sqrt{\frac{q_2}{q_1}} +1
\frac{r}{4}= \pm \sqrt{\frac{q_1}{q_2}} +1
r= \left(\pm \sqrt{\frac{q_1}{q_2}} +1\right)4
r= \pm 4\sqrt{\frac{q_1}{q_2}} +4
r= 4 \pm 4\sqrt{\frac{1}{0.5}}
r= 4 + 4 \sqrt{2}
But that isn't correct. That isn't the correct answer. The correct answer is:
r= 8 + 4 \sqrt{2}
Where does the extra factor of 2 come from making the 4 an 8?
This gives E1=E2
You made a mistake. The red line is wrong.
ehild
I am assuming I can't take the inverse of that thing like I did?
Would the more appropriate solution to cross multiply everything to get r alone?
hi erok81! :smile:
that'll still leave you with the problem of what the inverse of the RHS is :redface:
hint: 1 = √q1/√q1 :wink:
You can not. Try it with numbers: if 1/r = 2/3 +1
=5/3
is r=3/2 +1
=5/2?
You can take the reciprocal of both sides of an equation if neither sides can be zero. If
4/r =a+b
then
r/4=1/(a+b)
Multiply both sides by 4:
r=4/(a+b)
Your equation is
Substitute the numerical values of the charges q2=Q/2 and q1=Q.
\frac{4}{r}= \pm \sqrt{1/2} +1
Take the reciprocal of both sides.
ehild
  • · Replies 18 ·
