Finding magnitude and direction of resultant force
The problem involves calculating the magnitude and direction of the resultant force exerted by two rocket engines, one producing a thrust of 725 N directly forward and the other producing a thrust of 513 N at an angle of 32.4° above the forward direction.
  • Participants discuss breaking down the forces into components and applying the Pythagorean theorem to find the resultant force. There are questions regarding the correctness of initial calculations and the method for determining direction.
Some participants have offered guidance on using vector components and the Pythagorean theorem, while others express confusion about the formulas needed and the calculations performed. Multiple interpretations of the problem-solving approach are being explored.
There is mention of discrepancies between calculated and expected results, as well as uncertainty about how to proceed with finding the direction of the resultant force. Participants are also seeking clarification on the appropriate formulas to use.
azn4lyf89
A rocket fires two engines simultaneously. One produces a thrust of 725 N directly forward, while the other gives a 513-N thrust at 32.4° above the forward direction. Find the magnitude and direction (relative to the forward direction) of the resultant force that these engines exert on the rocket.
I tried finding the magnitude by doing 725+513(cos(32.4°)) and got 1158 N but for the answer it says its 1190 N. Did I do something wrong or is the book wrong? And I am not sure how to find the direction after I get the magnitude.
Hi Azn4ly, Well the way I would approch this is break everything up into components, and then add the componets of the vectors together and apply pythags therom. So think about it, break the 725 focre into components and then the 513 force into components. Try using that method :-)
You only calculated the X component of velocity. You need to factor the Y component in as Galadirith suggested by adding its value through the square root of the squares of the components.
I am still having problems with this problem. What formula would I use?
Pythagorean Theorem.
RSS - The Root Sum of the Squares.
The x and y components are at right angles and hence for the sides of a right triangle.
The relationship of the sides to the hippopotamus is
a2 + b2 = c2
hope this helps
  • · Replies 30 ·
