Finding the length of wire needed
  • Thread starter Thread starter meeklobraca
    Length Wire
meeklobraca
Two isolated farms are 12km apart on a straight country road that runs parallel to the main highway 20km away. The power company decides to run a wire from the highway to the junction box, and from there, wired of equal length to two houses. Where should the junction box be placed to minimize the length of wire needed?
Where should I start with this?
try and write an equation for the length of wire neded in terms of the juntion box position, then minimise
drawing a picture will help
also use the symmetry of the problem to simplfy the possible positions
I got nothing.
The shortest distance between two "farms" is a straight line. If the two farms were on opposite sides of the road, so that the straight line crosses it, this would be easy. What would the answer be then?
Now use the "symmetry" that lanedance mentioned.
I don't understand what you mean by using "symmetry" I also don't understand what your asking here.
The two farms are 12km apart. Ill try and trace out a diagram here.
FARM A
---------------------------------junct.----------highway
FARM B
So I tried to create 2 triangles between the farms and the junction, with one side of the triangle being 6km (since the question asks for equal length of wire.)
looking good, now try & write an equation for the total length of wire in terms of the junction box position
you could do it a few ways, but using of the distance junction box to the road (ie the other side of the two triangles) as your variable might be a good place to start
Im still lost as to where to start. What I am attempting right now is that I have 1 triangle and a straight length of wire.
I have the hypot. of the triangle = y, the base = x and the other side = 6. Hope that makes sense. I also have the length of wire = 20-x. If I can solve for one of these I can figure out the rest.
DO you recommend starting with the 20-x function? If so how?
the wire if i understand right, will be the length from highway to junction box, call it HJ, then 2 times the hypotenuse, JF
so length L(x)= HJ(x) + 2*JF(x)
you've already told me
HJ(x) = 20-x
what is JF(x)?
I don't know how we can figure that out. JF(x) = L - (20-x), I don't know where you can from there without knowing more of the variables.
I did some calculations and figured out x = 10, which then translated into a total length of wire of 33.3 km.
What do you guys think?
you need to show your calcs then
i'm not going to do the problem then check your answer, but i will confirm whether yoru thinking sounds right
Its diffcult without being able to show a diagram. Essentially I created 2 triangles, One triangle with the sides of 6 and t with a hypotenuse of x, and the other triangle with sides of 6, 20-t, and y. I created equations for x and y to single out the variable t. So then I did D = x + y then differentiated. From there I singled out t which you can find out 20-t and also x. 2 times x plus 20-t gives the answer.
Have you given any thought to what I said before?
I don't get what that means. I would need a diagram to understand what that means.
