Finding volume ratio between 2 vessels using ideal gases
3 replies · 2K views
Jamessamuel
I have been tasked with designing a feasible experiment to determine the ration between 2 vessels. I think i have a way that works on paper.
pV = nRT and the conservation of mass.
1.Start with 2 vessels of unknown volume x and y. they are linked with a pipe/valve.
the temp in x to start is t1(x) and in y is t1(y).
the catch is, I am keeping the pressure constant, so p(x) and p(y). This is the crucial idea, as I am going to increase the temperature of one to say, t3(x) leading to t4(y) being produced in the y vessel. I can use the conservation of mass so n(initial sum) = n(final sum) for moles, and rearrange to find x/y. However, is it a feasible procedure, does it work the way i would want it to? could i keep the pressure constant? I am not sure how...
We did it with an isothermal process, and have to justify using another process to find the same result.
regards,
james.
apologies for the typo, i want to find the ratio of volumes between 2 vessels. I can see the pressure and temperature, but they are effectively behind a wall and i can control pressure input and output only.
i can measure the temperature of the vessels and their pressures. I can also increase or decrease the pressure, although i would want it constant in this situation. I do not possesses apparatus to control the temperature though... so i guess i just answered my own question. I wanted to vary the temperature.
Regardless, could I perform the experiment and find the ratio using a process other than an isothermal one? that is the one we used, allowing gas to discharge into the other vessel from one (pressurised) and use the gas laws and conserve mass to find the ratio. I could keep pressure constant but I am not sure how i could use that.
Let's see if I understand. You are going to have different temperatures and different pressures in the two chambers to start with. Then, you are going to open the pipe between the two chambers and allow their pressures to equilibrate? Are you also going to wait long enough to get the temperatures to equilibrate, presumably with the surrounding room temperature? Is that your game plan?
Chet
