Force and work homework problem
The discussion revolves around calculating the force exerted by a man pushing a 330kg piano down a 28-degree incline, where the effective coefficient of kinetic friction is 0.40. The initial calculation for the force using F = mgsin(theta) resulted in 3237.3N, but there is uncertainty about whether this is correct. For the work done by the man, it was concluded that it would be zero since the angle between the force and displacement is 90 degrees. The work done by friction was calculated as -2472.8J, raising concerns about the accuracy of this value. Overall, the participant seeks validation of their calculations and guidance on the problem.
Farm4Life
I have all of my question pretty much divided out into formulas and just need some help with with what i am putting into it.
The question reads, a 330kg piano slides 3.6m down a 28degree incline and is kept from accelerating by a man who is pushing back on it parallel to the incline. The effective coefficient of kinetic friction is 0.40. Calculate a. the force exerted by the man.
Since the man is parallel to the incline, his direction would be the same as mgsin(theta) wouldn't it?
I got for the force, F=mgsin(theta)
=330kg(9.81m/s2)sin 90
=3237.3N
Is this correct? or should i be using something different to derive the force? I think this is right though.
b. The work done by the man on the piano.
Work=Fdcos(theta), but theta would be zero right because the angle created between the man and the normal is 90, and cos90= 0
So, work would be zero right?
c. the work done by the friction force.
w=-fd Would you use the force of the man for the equation?
N+Fy-mg=0
N=mg-Fsintheta
N=330kg(9.81m/s2)-3237.3N(sin28)
N=3237.3-1519.6
N=1717.33
f=0.40(1717.33)=686.9
W(friction)=-686.9N(3.6m)=-2472.8J
This answer seems a bit large, I am not sure if i did something wrong, or if that seems like it should be. What would be your advice please?
There is a few more questions to the problem, i have worked though them, but aren't very useful if i can't get these values correct.
Thanks!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
