Free energy in the free expansion of an ideal gas
In the discussion about the free expansion of an ideal gas, it is established that during this process, which occurs at constant temperature, the change in internal energy (ΔU), heat (Q), and work (W) are all zero. The calculation of the change in Gibbs free energy (ΔG) shows that it is negative when the final pressure (P2) is less than the initial pressure (P1), indicating that the free expansion is a spontaneous process. The conversation raises the question of whether ΔG, often interpreted as the measure of useful work done by the system, is still a valid physical quantity when no work is performed. It is clarified that ΔG represents the difference in free energy between two states and does not depend on the path taken or the work done. Therefore, a negative ΔG can occur without work being done, reinforcing that it serves as a theoretical measure of the maximum possible useful work that could be extracted from the system.
MexChemE
Hello PF! Consider the free expansion of an ideal gas. The process occurs at constant temperature, therefore, ΔU = 0, Q = 0, and W = 0. Suppose we are given the initial and final pressures of the gas, and we calculate ΔG = nRT ln(P2/P1). As P2 < P1, ΔG < 0. This is intuitive, as a free expansion is clearly spontaneous. My question is, ΔG is commonly (physically) interpreted as the opposite of the "useful work" done by the system, but in this case the system does zero work. Does this mean ΔG is not an actual physical quantity, but a helpful theoretical measure of the useful work that can be extracted from the system?
Thanks in advance for any input!
Chemistry news on Phys.org
All it really tells you is the difference in free energy between the two states. It does not include any specification of path, or work done.
Likes MexChemE
ΔG is commonly interpreted as the opposite of the maximum possible useful work (for a flow process) between the initial and final states.
Chet
Likes MexChemE
Got it, so the system doesn't have to do work for it to have a negative change in free energy.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
