Fundamental theorem of Calculus
perwiradua
Suppose a is a constant.
If G(x) = \int_a^x \Big [ f(t) \int_t^x g(u) du \Big ] dt, what is G\,'(x)?
My attempt,
G\,'(x) = f(x) \int_x^x g(u) du = 0,
and I am sure this is wrong.
My attempt,
If you had
G(x) = \int_a^x F(x,t) \, dt
in general, what would be your answer for ##G'(x)##? What happens if you specialize this to
F(x,t) = f(t) \int_t^x g(u) \, du ?
Thank you for the hint. This is my attempt at the proof which I mimic from that of the single variable case. Please check the rigour in the proof.
Let
\begin{equation*}
G(x) = \int_a^x F(x,t) dt.
\end{equation*}
Now
\begin{align*}
G(x+h) - G(x)
&= \int_a^{x+h} F(x+h,t) dt - \int_a^x F(x,t) dt \\[3mm]
&= \int_a^x F(x+h,t) dt + \int_x^{x+h} F(x+h,t) dt - \int_a^x F(x,t) dt \\[3mm]
&= \int_a^x F(x+h,t) dt - \int_a^x F(x,t) dt + \int_x^{x+h} F(x+h,t) dt \\[3mm]
&= \int_a^x \big [ F(x+h,t) - F(x,t) \big ] \; dt + h F(x+h,c) \\[3mm]
\end{align*}
for some c \in (x, x+h) by the mean value theorem for integrals. Therefore
\begin{equation*}
\frac{G(x+h) - G(x)}{h}
= \int_a^x \Big [ \frac{F(x+h,t) - F(x,t)}{h} \Big ] \; dt + F(x+h,c) \\[3mm]
\end{equation*}
and
\begin{align*}
G'(x) &= \lim_{h \to 0} \int_a^x \Big [ \frac{F(x+h,t) - F(x,t)}{h} \Big ] \; dt
+ \lim_{h \to 0} F(x+h,c) \\[3mm]
&= \int_a^x \frac{\partial}{\partial x} F(x,t) dt + F(x,x)
\end{align*}
since as h \to 0, x + h \to x and c \to x.
Now if F(x,t) = f(t) \int_t^x g(u) du. Then
\begin{equation*}
\frac{\partial}{\partial x} F(x,t) = f(t) g(x)
\end{equation*}
and
\begin{equation*}
G'(x) = \int_a^x f(t) g(x) dt + f(t) \int_x^x g(u) du = \int_a^x f(t) g(x) dt.
\end{equation*}
Let
\begin{equation*}
\end{equation*}
Now
\begin{align*}
G(x+h) - G(x)
\end{align*}
\begin{equation*}
\end{equation*}
and
\begin{align*}
\end{align*}
\begin{equation*}
\end{equation*}
and
\begin{equation*}
\end{equation*}
That is correct. There is a general formula for such problems that is often found in good calculus textbooks. Assuming everything is differentiable, we have:
\frac{d}{dx} \int_{a(x)}^{b(x)} F(x,t) \, dt = b&#039;(x) F(x,b(x)) - a&#039;(x) F(x,a(x))<br /> + \int_{a(x)}^{b(x)} F_x(x,t) \, dt
The proof is essentially the same as what you gave.
Likes 1 person
I would like to go back a bit and look at:
If \quad {\displaystyle G(x) = \int_a^{\psi(x)} f(t) dt } \quad then \quad G\,&#039; (x) = \psi\,&#039; (x) f(\psi(x)).
My attempt at the proof, which again mimic the proof of the basic case:
Proof
\begin{align*}
G(x+h) - G(x)
&= \int_a^{\psi(x+h)} f(t) dt - \int_a^{\psi(x)} f(t) dt \\[3mm]
&= \int_{\psi(x)}^{\psi(x+h)} f(t) dt \\[3mm]
&= \big [\psi(x+h) - \psi(x) \big ] f(\psi(c))
\end{align*}
for some c \in (x, x+h) by the mean value theorem.
Therefore
\begin{equation*}
= \frac{\psi(x+h) - \psi(x)}{h} f(\psi(c))
\end{equation*}
and
\begin{align*}
G\,'(x) &= \lim_{h\to 0} \frac{\psi(x+h) - \psi(x)}{h} f(\psi(c)) \\[3mm]
&= \psi'(x) f(\psi(x))
\end{align*}
The bit that I am not comfortable with is going from
{\displaystyle \int_{\psi(x)}^{\psi(x+h)} f(t)} dt \quad to \quad {\displaystyle \big [\psi(x+h) - \psi(x) \big ] f(\psi(c)) }
Perhaps more explanation is needed here to make it rigorous?
Thank you sir for stating the general case. I saw that in a textbook a long time ago but I did not jot it down and I have been trying to find it ever since. All the Calculus textbooks that I refer to do not state the result.
Proof
\begin{align*}
G(x+h) - G(x)
\end{align*}
Therefore
\begin{equation*}
\end{equation*}
and
\begin{align*}
\end{align*}
The formula Ray is talking about is quoted here http://en.wikipedia.org/wiki/Leibniz_integral_rule. And for justifying your step, you gave the reason. It's a formulation of the mean value theorem. You may need to state some assumptions about continuity, but other than that it's perfectly rigorous.
Likes 1 person
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
