How Do Galilean Transformations Affect Measurements in Different Frames?
The discussion revolves around applying Galilean transformations to analyze the positions of events in different reference frames, specifically a train and a track. The train, moving at a constant speed of 25 m/s, is 120 m long, with the rear passing a signal light at t = 0. After 12 seconds, the engineer turns on the headlight, which is calculated to occur at 420 m in the train frame and 720 m in the track frame. The calculations confirm that the front of the train advances 300 m during this time, leading to the specified positions. The importance of correctly defining the coordinates for both frames is emphasized for accurate measurements.
austim14
βI solved this problem but I do not know if it is correct becasue there is no way to check it:
Imagine that we define the rear end of a train 120 m long to long to define the origin X'=0 in the train frame and we define a certain track signal light to define the origin X=0 in the track frame. Imagine that the rear end of of the train passes this sign at t+t'=0 as the train moves in the +X direction at a constant speed of 25 m/s. 12 seconds later, the engineer turns on the train's heasdlight. A) Where does this event occur in the train frame? B) Where does this event occur in the track frame
Use Galilean transformation equations for position. β is the contstant velocity.
t=t'
x'=X- β*t
Here is my work: 25m/s*12s=300m
300m+120m= 420m
Train Frame 420m
420m=X-300m
X=720m
Track frame 720mIs this correct?
300m+120m= 420m
Train Frame 420m
What is the speed of the train relative to the train (=in the train frame)?
I agree with the calculations of the second part if you fix the value from (A).
I think it's the 25 m/s
If the train is 120 M long, and the rear of the train is at x' =0, what is the x' coordinate of the front of the train? (presumably the engineer is situated in the front of the train). (Assume that you have a set of coordinates permanently laid out along the floor of the train from the rear of the train to the front of the train). The front of the train is always situated at this x' location.
Assume you also have a set of coordinates permanently laid out along the side of the track starting at the signal at x = 0. At time t = t' = 0, what are the x coordinates of the rear and the front of the train? During the 12 seconds, how far does the front of the train advance along the x coordinates at the side of the track? What is its x coordinate after these 12 seconds?
