Given kinetic energy and momentum, find mass and speed
To find the mass and speed of an object with a kinetic energy of 293 J and momentum of 26.7 kg·m/s, the relevant equations are kinetic energy (K = 1/2 mv^2) and momentum (P = mv). By equating these formulas, two equations can be established with the unknowns being mass (m) and speed (v). Solving these simultaneous equations will yield the required values for mass and speed. Understanding the relationship between kinetic energy and momentum is key to solving the problem effectively.
okool
An object has a kinetic energy of 293 J and a momentum of magnitude 26.7 kg·m/s. Find the speed and the mass of the object.
I don't know what equations I need...I know K=1/2mv^2 and P=Fv but I don't know how to relate them
Since you know the formulas, just equate them. You will have two equations with two unknowns to solve simultaneously.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
