Heat of Transformation Question
The discussion centers on the relationship between heat of vaporization and pressure for substances like water. It highlights that the heat of vaporization does indeed vary with pressure and is uniquely dependent on temperature. The equilibrium vapor pressure is a critical factor, as it is a function of temperature, influencing the heat of vaporization. Additionally, when water transitions directly from solid to gas—bypassing the liquid phase—the heat of vaporization remains consistent with other phase changes, as described by the Clapeyron equation, which connects vapor pressure, temperature, heat of vaporization, and the specific volumes of the phases in equilibrium.
MathewsMD
Given a substance, for example water, does the heat of vapourization vary with pressure or any other variables?
Also, at a specific pressure, water (like all other substances, but at its own respective pressure) changes phases from solid to gas without any intermediate phase. Would the heat of vapourization be the same here as in any other case? (The second question is essentially an extension of the first.)
Chemistry news on Phys.org
The equilibrium vapor pressure is a unique function of temperature, as is the heat of vaporization.
When ice evaporates, the equilibrium vapor pressure is a function of temperature, as is the heat of vaporization.
The Clapeyron equation describes how the vapor pressure, the temperature, the heat of vaporization, and the specific volumes of the two phases in equilibrium are related.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
