Heat Transfer of Horizontal Closed Loop Systems
The discussion focuses on finding governing equations for heat transfer in horizontal closed loop systems, particularly regarding the Nusselt Number's relationship with Reynolds and Dean Numbers. Participants suggest resources like the textbook "Fundamentals of Heat and Mass Transfer" for foundational knowledge. They also mention that detailed thermal analysis may require computational tools such as COMSOL or CFX. A simple lumped-parameter model could be developed if the system's general heat transfer properties are known. Overall, the conversation emphasizes the need for specific equations and methodologies in analyzing heat transfer in geothermal systems.
NSX
Does anyone know where I can find the governing equations on the heat transfer of a horizontal, closed loop system?
e.g. http://www.eere.energy.gov/consumer/images/closed_loop_system_horiz.gif
I've tried searching online, and all I can find is the general overview, no equations :frown:
In particular, I know that the Nusselt Number is some function of the Reynolds and Dean Numbers in this case -- what it is exactly I have no idea.
Can anyone recommend any articles, textbooks, anything?!
Thanks
The linked image is that of geothermal system.
The standard text on heat transfer is -
Fundamentals of Heat and Mass Transfer (Hardcover)
by Frank P. Incropera, David P. DeWitt, Theodore L. Bergman, Adrienne S. Lavine
John Wiley & Sons
Here is one example of heat transfer -
http://en.wikipedia.org/wiki/Heat_transfer_coefficient
Detailed thermal analysis would require a FEM-based heat transfer computational package such as COMSOL or CFX.
One could perhaps develop a simple lumped-parameter model if one new the general heat transfer properties of the system, i.e. hot and cold side temperatures, properties of the heat transfer fluid, ground and heat exchangers.
John Wiley & Sons
Thanks for the help.
That's actually what I was planning to do, using the LMTD method and a 2D approximation.
I have the Introduction to Heat Transfer of the book you mentioned, and it wasn't a help. I will read into the version you suggested.
Thanks
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
